586,094 active members*
4,206 visitors online*
IndustryArena Forum > Community Club House > Hardinge Cobra 51 & Fanuc 21i-T Question
    May 2010
    Hello guys, I'm new! I am in need of a little help.
    I've been trying to make a 7/8-6 ACME thread on this 4140 shaft. My hole program runs great, except for one problem. The first two to three threads do not seem to be exactly the right pitch... If I cut that end off, the rest of the threads are great... They screw into the mating piece no problem... I've spent the last 2 days rechecking everything in the programing and mechanically. Everything checks out.
    Anyone have any advice?
    Oct 2009
    118
    There is a formula to determine how far Z+ to allow Z axis to get up to speed before starting the cut. If you start Z+ about the amount you cut off plus a little, it should work fine.
    May 2010
    My threading pattern starts around 1" away from the thread:
    G97S1200M4
    G0Z-1.1M8
    X.845 (1ST PASS .015 DOC)
    G32Z-5.275F.16667
    G0X1.2
    Z-.9
    X.815 (2ND PASS .015 DOC)
    G32Z-5.275
    G0X1.2
    Z-.9
    X.785 (3RD PASS .015 DOC)
    G32Z-5.275
    G0X1.2
    Z-.9
    etc...
    I guess that I could back it up some more, but I think that it would hit the live center.
    Jul 2005
    380
    Back up your Z axis start point by an additional .25" in the positive direction and you should be ok. Prove out accordingly.
  1. hardinge conquest 42 VS cobra 42
    By mls in forum Hardinge Lathes
    Last Post: 09-07-2010, 10:42 PM
  2. G73 Cycle on Hardinge GT-27 / Fanuc-18T
    By jdr1961 in forum Hardinge Lathes
    Last Post: 01-06-2010, 10:33 PM
  3. Hardinge cobra 65 collet closer
    By vsmvj in forum Uncategorised MetalWorking Machines
    Last Post: 07-30-2009, 03:13 PM
  4. Hardinge TT-65 w/ Fanuc 18i-T
    By Jeff_Mezzo in forum Hardinge Lathes
    Last Post: 01-29-2009, 03:24 AM
  5. Parameters on Cobra 42 Hardinge
    By Niall in forum Bridgeport / Hardinge Mills
    Last Post: 07-16-2004, 10:38 AM
