586,108 active members*
3,266 visitors online*
    Dec 2008
    19
    Cutting aluminum treadplate.
    Hi. I'm looking for help setting up to cut 16? ga. aluminum treadplate.
    I'm using a dynacnc w/cutmaster 52 machine torch. 60A tip.
    Can someone recommend cut speed and tip setoff from plate?
    what happened to DynaCNC?
    Oh . . I can't get the THC to work either. When I turn it on in Mach the torch ignites and just sits still. Turn it off and I can cut my program but of course the tip does move with the steel. Any help would be greatly appreciated.
    The tech guy that used to be there for Dyna wants to charge for his help. We are using this at a school where there is no money for "tech support"
    Jul 2005
    2415
    Cut the treadplate from the back if possible. Cutting 16ga AL with a 60 A tip is like carving with a chainsaw. Use a smaller tip and lower current to get better cuts in thin material.
    The problem with the THC sounds like you are not getting the ARC OK. It tells MACH that it has a valid ARC and triggers it to release motion after the pierce.
    If you have the DYNACNC 1000 series control we still support the controller for free. If you have the later 4000 or 6000 controller you may be SOL for free support.
    TOM caudle
    www.CandCNC.com
    Oct 2007
    4
    Orangejbird
    Did you get your machine running for the plasma?
    Dec 2008
    19
    Not yet! Gotta call a guy that PM'd me who thinks he can help.
    Thanks for looking.
    Oct 2007
    4
    orangejbird
    Is it possible to give you a call, or if you want to you can call me I think we can help one another. I have the same machine.
  1. RFQ - cutting 1 5/8 aluminum rod
    By jhuebbe in forum Employment Opportunity
    Last Post: 07-24-2009, 03:33 AM
  2. Cutting .250+ Aluminum
    By Drools in forum DIY CNC Router Table Machines
    Last Post: 06-04-2009, 06:28 PM
  3. 3/16 Aluminum cutting
    By zeoncomp in forum MetalWork Discussion
    Last Post: 03-14-2008, 05:54 PM
  4. K2 cnc Aluminum Cutting
    By Ed Williams in forum MetalWork Discussion
    Last Post: 03-16-2006, 07:38 AM
  5. Aluminum Cutting
    By Tazzer in forum DIY CNC Router Table Machines
    Last Post: 07-29-2003, 06:09 AM
