586,116 active members*
3,343 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Wiring Keling power supply to the electric plug...
Results 1 to 6 of 6
    Apr 2006
    225
    Cool Wiring Keling power supply to the electric plug...
    Hi all,
    I just got a 5020 keling power supply, on primary to connect them on the wall electric plug how I'm suppose to proceed?
    On the website it says 2 red wires to neutral and 2 red wires to hot( I will run on 110v )
    Does that means I will have to like solder both tips of the red wires together and both of the black and then each pair of wires go one on each side of the plug?
    like this
    ==reds=====----- o
    ==blacks====----- o <--- little ''o'' s are the power plug
    I'm asking because I messed up one transformer last month... = (
    Thank you
    check here
    http://www.kelinginc.net/KL-5020.pdf
    AC power connections:
    115Vac input: – 2 red wires to neutral & 2 black wires to hot.
    220Vac input: – 1st red wire to neutral, 1st black wire to 2nd red wire, and the 2nd
    black wire to hot.
    www.kelinginc.net
    Apr 2006
    225
    It didn't help much...
    I have checked before, in my post I mention this but I'm not quite sure if I get it right maybe its because the language and I dont understand the electric terms of hot and neutral, house plugs don't have positive or negative ( if its that what it means... )
    Thank you
    Nov 2009
    4415
    Yes the 2 red wires are tied together if only 110 is used as the source. 220 is made from using 2 different 110 legs. That is why they had to seperate the red and 2 blacks when 220 is used.
    Feb 2007
    4553
    Post
    See pictures for more information.
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    Apr 2006
    225
    Thank you for the replies, with the drawing stayed a lot easier.
  1. Power supply plug HELP!!!!
    By ChipKing in forum Bridgeport / Hardinge Mills
    Last Post: 04-22-2010, 11:58 PM
  2. Keling power supply
    By judleroy in forum CNC Machine Related Electronics
    Last Post: 04-19-2010, 04:36 AM
  3. Keling power supply
    By yoyomin in forum Automation Technology Products
    Last Post: 01-23-2010, 04:00 AM
  4. Keling 5010 power supply wiring
    By ronncat in forum Automation Technology Products
    Last Post: 12-13-2009, 06:17 PM
  5. Keling power supply?
    By mcruff in forum Automation Technology Products
    Last Post: 09-24-2007, 03:11 AM
