Good day to all. I have an Okuma CNC grinder (GA/GP-N Series) and am having trouble opening and closing the door. It was retrofitted with the GKN 5020 Automatic Door Modification, by Okuma. The machine must be in Single-block mode in order to open and close the door. Obviously while in-cycle, I need to run in auto. As soon as I switch from single-block, the door opens, automatically. Also, when the door is closed and single block is turned off, the door will not open, even in manual, when you push the door open pb. Any help would be greatly appreciated.
