586,055 active members*
4,429 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Countersink Depth Chart
Results 1 to 9 of 9
    Sep 2007
    356
    Awhile back I found a chart that told you how deep to run a countersink to obtain a fixed diameter. I can't seem to find where I found it and I can't find my printout of it. I know there are calculator programs that you can buy, but this was a really cool chart. It had all dimensions for 82', 90' and 100' countersinks. Does anybody know where to find something like this?
    Sep 2008
    117
    I can compose an Excel spreadsheet for this if you're interested. I can't do it overnight however. As I get older I get slower. If you want it, I'll do it. Let me know.
    Gene
    Feb 2010
    Countersink Depth Calculator
    Here is a calculator that solves for depth: http://janproducts.com/countersink_calculator.html
    927
    Drill Point Angle >>>> Factor
    (60 degree)>>> .866 x Dia = Point Depth
    (82 degree)>>> .575 x Dia = Point Depth
    (90 degree)>>> .500 x Dia = Point Depth
    (118 degree)>> .300 x Dia = Point Depth
    (120 degree)>> .388 x Dia = Point Depth
    (135 degree)>> .207 x Dia = Point Depth
    Dia is hole chamfer diameter, not tool diameter.
    Point depth is how deep to drill to get the desired chamfer diameter with that drill point angle.
    Re: Countersink Depth Chart
    Ok,
    so if my diameter of my countersink of the material is .75 of 82 degrees, im going to take .575x75=.43125 for depth. isnt that a little bit to much...should i take that awnser .43125/2=.215625
    Oct 2013
    64
    90 degrees would be .375" deep. You'd have to go deeper with an 82 degree, so .43125" is the answer you're looking for.
    Oct 2013
    Quote Originally Posted by wms View Post
    Thank you so much!
    Quote Originally Posted by journeymachine View Post
    Ok,
    Hi Journey,
    Yes for a 3/4 diameter chamfer, 0.4312 is your depth. I use these constants all the time and they work great. They are also what you would use to calculate the tip length of a drill. This will help make sure that you drill deep enough, but not wastefully too deep when drilling thru a part. Stock thickness + drill point length + fudge factor to clear/break exit burr. (0.050 - 0.10 or so depending on diameter.)
    Keep in mind that these numbers work the best on pointed 3 flute chamfers and near perfect on drills too, but many chamfers like the 6 flute kind from MaFord and similar have a truncated tip. This truncation diameter needs to be measured or is given in their literature and has to be accounted for. Otherwise you will drill your first countersink way too big. All you do is subtract the tip diameter from the countersink diameter you want and multiply that against the constant and you're good. No head scratching or jumping thru hoops needed.
    Quote Originally Posted by the_gentlegiant View Post
    Hi Journey,
    Ha-ha... I just responded to a ten year old thread. Sheesh! Pay attention dude!
    Two head slaps in one week. Maybe I need a vacation.
  1. Countersink holes
    By glendion in forum EnRoute
    Last Post: 07-17-2012, 04:08 PM
  2. Replies: 2
    Last Post: 02-04-2012, 05:27 PM
  3. Help with countersink
    By gumba in forum MetalWork Discussion
    Last Post: 07-07-2011, 03:33 AM
  4. Looking for 90 deg. countersink to cut underside
    By georgebarr in forum MetalWork Discussion
    Last Post: 11-01-2009, 11:48 PM
  5. countersink possible in alphacam?
    By oakleigh in forum Uncategorised CAM Discussion
    Last Post: 08-21-2009, 10:59 PM
