586,116 active members*
3,474 visitors online*
    Apr 2010
    Clifton servo identification
    Hi all,
    I just bought a supermax (series I -j head) that has a retrofitted cnc system from retrotec. It is a retrotec cnc 8800. It was functional until the monitor fried when I was buying it. Retrotec is no longer in business ( and is not the same as the company in Texas)
    It has nc400 drives a1520 by contraves and servo motors that I am trying to ID. Clifton will not help after 4 emails and 3 calls.
    I am looking at getting rid of this system (possibly).
    The motors have 4 brushes and 2 wires. Not including the 5v encoder by dynamic research.
    The motors have no tags.
    Shaft is 5/8 dia
    the motor is 4" in dia and 5.62" long (not including encoder enclosure)
    one of the pcb's have a +- 16vdc on it
    I have hooked up a few predesigned systems, but I not that electonically adept at finding a modern driver for this motor and do not really want to at this point .
    Does anyone have any recommendations in identifying these?
    (I realize how silly of a question this is-and I am not looking for a serial/model #)
    motor ID is my issue, not the contraves drives.
    any recommendations would be greatly appreciated as I do not have info on this Retrotek 8800 system.
    For me to decide what I want to do would require to ID this motor.
    Thanks in advance
    best regards
    rob
    24221
    Generally DC servo's are the easiest to sub, you should be able to find a replacement of some kind on ebay, in fact there is a seller that has 3 SEM servo's off a Knee mill that should fit the bill.
    Al.
    Albert E.
  1. Another Clifton Cheap Servo ?
    By Ken_Shea in forum CNC Machine Related Electronics
    Last Post: 10-09-2005, 01:25 AM
  2. Cheap 0 Clifton and servo drive selection (advice needed)
    By Konstantin in forum CNC Machine Related Electronics
    Last Post: 04-14-2004, 04:21 PM
  3. How about those Clifton Servos?
    By Konstantin in forum DIY CNC Router Table Machines
    Last Post: 04-10-2004, 12:27 AM
  4. Servo motor identification help
    By kong in forum CNC Machine Related Electronics
    Last Post: 04-01-2004, 10:28 PM
