586,077 active members*
3,911 visitors online*
IndustryArena Forum > MetalWorking Machines > Knee Vertical Mills > King Rich KRV-2000 Knee Mill CNC Conversion
Page 11 of 11 91011
Results 201 to 207 of 207
  1. #201
    Sep 2008
    157
    Re: King Rich KRV-2000 Knee Mill CNC Conversion
    New project to make a Mill Riser Block out of a piece of hydraulic cylinder 406 O.D. 340 I.D and 216mm long. It was bandsawn from a barrel 3.7m long that weighed 1300kg. This piece alone is around 75kg. A Mill riser block fits on top of the column and raises the turret 200mm to allow more clearance between the spindle and the table for larger jobs like boring a small engine or drilling with a long drill bit or tapping with a tapping head or working over a large rotary table or vise.
    They can be purchased for a Bridgeport secondhand for a reasonable price but the King Rich is a bit larger and very expensive. Access to a piece of stock like this made the project viable to build one..
  2. #202
    Sep 2008
    157
    I needed to register the Riser Block to both the Column and the Turret.
    https://youtu.be/NNfbUSOSuYQ
    Attached Thumbnails Attached Thumbnails 20191209_130017 (1024x576).jpg   20200417_162539 (1024x576).jpg   20200417_162633 (1024x576).jpg
  3. #203
    Sep 2008
    157
    After sorting out a method of registering the riser block, the turret was lowered back into position and the head was trammed so I could continue machining.
  4. #204
    Sep 2008
    157
    The tram is good but the surface finish can be improved by changing the tool path exit and including a spring pass.
  5. #205
    Sep 2008
    157
    When I was happy with the surface finish on the first side, the riser block was flipped over and the rough sawn second side was machined flat.
  6. #206
    Sep 2008
    157
    Installation required the 70kg riser block to be transfered from the table to the column.
  7. #207
    Sep 2008
    157
    The 14 inch long 5/8 UNC hold down bolts had 15/16" AF hex heads. The original 6 inch bolts have 23mm AF heads which match the supplied ring spanners in the Mill Tool Kit.
Page 11 of 11 91011
  1. Conversion of a King Rich 3000.
    By Desertrunner in forum Knee Vertical Mills
    Last Post: 01-05-2014, 09:09 AM
  2. Knee mill conversion
    By evo4wrx in forum Australia, New Zealand Club House
    Last Post: 09-16-2008, 04:31 PM
  3. Nikken TT35 Tooling for King Rich Turret
    By fabianlj in forum Bridgeport / Hardinge Mills
    Last Post: 05-23-2007, 01:58 PM
  4. knee mill conversion
    By mtechserv in forum Knee Vertical Mills
    Last Post: 12-04-2004, 07:30 PM
