586,594 active members*
2,863 visitors online*
    Jul 2009
    28
    Machine recomendations
    At present I have one of those Chinese non cnc mills. Its a harbour freight X2 or similiar. I've had it several years and use it mostly on aluminum and plastics, cutting or drilling holes in small enclosures and faceplates. I added some cheap digital readouts several years ago and it made the machine way more easy to use as I do my panel leayouts on a cad program so I had all the coordinates. The displays don't have a remote display so you have to look in three places to get X,Y,Z readings, now the displays are acting up and I am also running into problems with the small X,Y movement (4" x 8").
    I do a lot of electronic design and sometimes need one of circuit boards, some pretty basic. I was thinking of going to CNC mill so I could also do some circuit boards also.
    Searching the web the one I seem to like is the Tormach 770. I'll have around 7x12 X,Y movement, 10000 Rpm spindle for small cutters on pcb, plus more power - just in case I'm doing something larger.
    What recommedations do you guys have? I was scanning internet for some used ones but could find any.
    Geoff
    Winnipeg, Canada
    Feb 2007
    4553
    Post
    Geoff,
    Novakon is up in your neck of the woods.
    http://www.novakon.net/nm-145.html
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    Jul 2009
    28
    Thanks for the link, I hadn't seen them. I guess all mills will have there ups and downs so I guess I got to look at all and see. I won't be using it too much so if I could find a suitable used one i would be happy. I've look a fair bit on line but haven't really found any used ones.
    Geoff
  1. spindle recomendations
    By jcbeck84 in forum Mechanical Calculations/Engineering Design
    Last Post: 01-18-2009, 03:31 PM
  2. recomendations???
    By john matthews in forum Benchtop Machines
    Last Post: 08-09-2008, 08:40 PM
  3. VFD MANF recomendations
    By vmax549 in forum Phase Converters
    Last Post: 07-08-2008, 07:31 PM
  4. Recomendations for smaller machine?
    By rlrhett in forum DIY CNC Router Table Machines
    Last Post: 01-19-2007, 05:00 AM
  5. 4-5 axis control recomendations for home built horizontal machine
    By Kmed in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-17-2005, 11:04 PM
