diy Mini lathe test bed
well here is the "throw it together as fast as I can" mini lathe..
Had to do something to fill all those voids in my schedual. (nuts)
its all low buck.. a test be for all the cam systems out there So far Mach3 is the winner.
first picture is of the somewhat finsihed controler box.
second is Enco lathe. just a slightly higher quality HF lathe
third is the x limit switch
forth is the z limit switch
fifth is a slightly blurry pic of the encoder for spindle timing. (would make another but am at work.)
thanks
Michael T.
"If you don't stand for something, chances are, you'll fall for anything!"
