586,103 active members*
3,855 visitors online*
    Sep 2008
    43
    circle cutting wizard
    Just starting out and Mach 3 circle cutting wizard does not zero from the center of the circle. WTF?
    I dont know how to write code and just purchased a small cnc mill/lathe wanting make some crafty stuff. Shopmaster VSD
    Is there a source of wizards to download for Mach 3 or is it not that easy?
    Are you entering 0,0 for the center? Not sure I understand the problem?
    There's a another circle wizard here, but I don't really know of any others.
    http://www.cnczone.com/forums/showthread.php?t=70480
    Sep 2008
    43
    Yeah, I am using 0,0 another thing as well,
    the box that asks for the diameter, actually is radius.
    SOMETIMES
    If I enter 3 I get a 6" circle but if I enter 2 the circle is not 4".
    I cut four circles and just changed the diameter number. I expected the circles to be centered but they were gradually offset on one of the axis.
    Just checked, and it works fine here. Make sure your IJ mode is set to Incremental, and not Absolute. Change it in General Config.
    Mar 2016
    Re: circle cutting wizard
    I had the same problem. changed the settings and worked just fine.
    H
  1. Replies: 16
    Last Post: 02-05-2014, 08:21 PM
  2. Newfangled Circle wizard problem
    By MFchief in forum Tormach Personal CNC Mill
    Last Post: 02-23-2012, 06:27 AM
  3. mach 3 wizard circle cutting
    By billmiller in forum Shopmaster/Shoptask
    Last Post: 05-28-2010, 11:02 AM
  4. circle cutting
    By soundwaves in forum Joes CNC Model 2006
    Last Post: 11-13-2008, 06:46 AM
  5. circle cutting wizard problem
    By kb7vms in forum Mach Wizards, Macros, & Addons
    Last Post: 11-06-2006, 06:14 AM
