586,103 active members*
3,304 visitors online*
IndustryArena Forum > CAM Software > CamBam > Using CamBam and Kcam together
    Feb 2010
    21
    I'm trying to get CanBam Gcode files to work in Kcam. I use CamBam to create a toothed gear. I can create the milling paths and view them in CamBam, and generate a Gcode file. When I open the Gcode file in Kcam, it compiles but hangs on "optimizing feed rates" and crashes Kcam. The GCode shows nicely in NCplot.
    Has anyone had this experience and can provide suggestions? Perhaps there's a setting on CamBam that Kcam can't digest?
    Any help is much appreciated.
    Feb 2005
    521
    I came across this CamBam forum post...
    http://www.cambam.co.uk/forum/index.php?topic=714.0
    It sounded like very small arc moves may have caused a problem for Kcam.
    The post above describes how you can change the CamBam post processor to set a minimum arc size. Arcs below this size will be output as line moves.
    Fingers crossed!
    Quote Originally Posted by hondaman900 View Post
    www.cambam.co.uk
    Feb 2010
    21
    Sounds like this is on the right track, but I can't find the MinimumArcLength property in the Tools>Options. I'm using CamBam v.0.9.3650.148. Any suggestions?
  1. Importing CamBam Gcode into Kcam
    By hondaman900 in forum Uncategorised CAM Discussion
    Last Post: 05-23-2010, 07:31 AM
  2. Kcam
    By tel1 in forum Uncategorised CAM Discussion
    Last Post: 12-02-2007, 01:54 PM
  3. Kcam 4
    By mwestern in forum Uncategorised CAM Discussion
    Last Post: 09-10-2007, 02:15 PM
  4. Kcam and rpm´s
    By auvecu in forum Community Club House
    Last Post: 07-18-2007, 07:11 AM
  5. KCam.ini
    By pminmo in forum Uncategorised CAM Discussion
    Last Post: 06-12-2004, 07:30 PM
