Hi All,
Has anyone tried the Predator over rides for feed rates?
For instance, If I post out of V23 with feed rates that are F100. , then load the posted program into Predator editor. If I turn up the feed rate over ride and apply to a section of the program, all Feed rates over 19.99 loose the decimal. If I take F100. to 200%, I get F200 (no decimal). Then I have to go back and use find and replace to correct all feed rates over 19.99 IPM.
Is there a newer Bobcad Predator? I still use the one that was bundled with V22.
Thanks in advance,
Robert
