586,117 active members*
3,627 visitors online*
IndustryArena Forum > CAD Software > Solidworks > How do you simulate with welded beams?
    Apr 2008
    28
    I have an assembly in Solidworks which is primarily made of square tubing which is welded together. How do I tell Solidworks COSMOS that the square tubing is welded together?
    The joints are not at the ends of the beams either, so the automatic joint stuff wont work.
    Stuff i can use: AutoCAD 2010, AutoCAD Inventor 2010, Solidworks 2009, MasterCAM X2/X4, CNC's FADAL, and Hurco 3-axis CNC Mill
    Jun 2010
    Bump
    I would like to know as well. I am working on a headache rack and would like to simulate the complete part.
    Jan 2004
    3154
    I believe you need the full version of cosmos FEA to do this.
    If I remember correctly, I have saved things like that as a part (single entity) to run tests on. It will not be truly accurate but in some cases close is OK.
    www.integratedmechanical.ca
    Jun 2010
    Thank you darebee
    I'll have to load cosmos I don't currently have it but my superior does.
  1. how can I combine two beams ???
    By cosmo2 in forum Mechanical Calculations/Engineering Design
    Last Post: 09-19-2009, 11:34 AM
  2. 2 or more CO2 Laser beams combining?
    By Konstantin in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-21-2009, 07:08 PM
  3. Machining brass I beams.
    By tirebiter in forum MetalWork Discussion
    Last Post: 04-26-2007, 10:51 AM
  4. How to combine two CO2 laser beams?
    By jlew in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-19-2007, 01:29 AM
  5. Simulate help
    By Dfennell in forum BobCad-Cam
    Last Post: 01-27-2007, 06:18 AM
