I'm currently making some drawings of an engine but it's a tight squeeze between the bores because of the cylinder setup.
So i'm wondering if it is possible to use maybe chrome moly tube as cylinder liner?
The piston will be alu silica but the piston rings is an X-factor here.
I would like to avoid the use of cast rings so i need an alternativ material in combination with steel liner.
The bore is about 40mm.
