586,103 active members*
3,205 visitors online*
Results 1 to 6 of 6
    Aug 2007
    793
    what "@" sign means
    controller 11M
    periodically "@" blinks at right lower corner of the CRT
    what does it mean?
    Mar 2007
    122
    Does this happen when you enable high speed function? There are parameters to change so different things can flash there. I once saw a machine that would flash ' *uckyou ' instead of ' ai nano '.
    Aug 2007
    793
    we've got this machine recently
    it's 1985 production year
    didn't perform any machining until
    I know Fanuc opened macro B option on it
    Jun 2008
    1511
    Hey Guhl,
    I vaguely remember this happening on one of my old 10t’s but do not recall off hand what exactly it meant. I thought maybe something with condensing programs but do not recall specifically. When I get some time I will dig up some old notes and see if I got anything written down.
    Stevo
    Jun 2010
    161
    I've also seen a flashing @ on the status line, at times. According to the 10/11/12T Operators Manual, the @ symbol on the status line of the display indicates that 'data is being written into bubble memory'. This only applies to Series 11 and 12, since the Series 10 CNC does not use bubble memory.
    Aug 2007
    793
    thanks to all
  1. Replies: 12
    Last Post: 06-27-2012, 12:30 PM
  2. "motor steps per resolution" and "driver microstepping" settings
    By margni74 in forum LinuxCNC (formerly EMC2)
    Last Post: 10-24-2009, 08:33 AM
  3. "J" head type "millport"(tiwan,1980) clutch
    By marksbug in forum Bridgeport / Hardinge Mills
    Last Post: 08-17-2009, 04:48 PM
  4. Replies: 4
    Last Post: 11-09-2007, 06:59 PM
