Originally Posted by
mactec54
Magnum164
Yes a good reason, is when using a solid shank the R8 spindle is only rated for a 2" dia cutter, putting a 3" is stressing the spindle,Can you go bigger, yes You can,but can only do very light cuts like .010 etc, & will have to have a solid shank
The 3" face mill has a 1" mounting hole for a reason, this alone is telling you something a 4" has a 1-1/4" to 1-1/2 mounting hole for a normal face mill
So putting a 3/4" straight shank on a 3" face mill will tell you that a 3/4" R8 collet is not going to hold it very well
I'm sure Tormach will tell you what size face mill you can run with the TTS system safely
