586,655 active members*
3,608 visitors online*
Results 1 to 7 of 7
    Jan 2009
    4
    Question OiM cutting feedrate problem
    I am relatively new to machining and am having problems getting with the programmed feed rate. If I post more than one tool such as a roughing pass and then a finishing pass the second tool (and all following tools if there are other sequences) runs at roughly 65 to 70% of the programmed feed rate. The control displays the called feedrate as it is programmed, but the actual feed rate is reduced just like you turned the feed override knob down. If anyone knows what needs cancelled or changed after the first tool sequence I would greatly appreciate the help! My control is a Fanuc OiM control and it is on a 2004 Hardinge VMC 1250II.
    Aug 2009
    684
    It sounds like your finishing tool paths are not being processed quickly enough and your controller is adjusting the feedrate to suit.
    You need to look at what options you have purchased with the controller regarding 'look ahead' modes/commands.
    Search this site for info on AICC or G5 or G8 settings/parameters.
    You could also alter the tool path style off-line to improve feedrates.
    DP
    Jan 2010
    99
    at least from 0i-mC forward G8P1 is always available and AI APC (called with G5.1 Q1) is available without option purchase...
    so you should have:
    Code:
    safety code
    M6 toolchange
    before g43, use:
    G8P1
    G5.1Q1R5 (the r is optional, depends if you have aicc or nano or...)
    apply tool offset (g43)
    work offset
    start cutting
    there are limitations as to what can and can't be used in AI APC mode, particularly not rigid tapping in most cases, but read around the forum there are lots of explanations
    personally i have put g8 and g5.1 inside my toolchange macros (m6)... and disable them with my rigid tapping (m29) macro... and never run into issues on the newer i-series controls... so they are always on typically
    - gwarble
    Jan 2009
    4
    Found the solution
    Thanks for your replies. I finally found in the Fanuc book where the machine reduces the feedrate by the ratio of the cutter center path radius divided by the actual cut path radius. There is an override parameter 1710 that will allow a minium reduction % to be used. Thanks for your help!
    Feb 2008
    29
    Radius speed reduction
    In this case you should notice that when going around radius from the outer part the feedrate should increase. Not sure but in some cases machine can even increase RPM - it depends on settings.
    Mar 2011
    I having a similar problem too. The machine is working fine at the beginning until 1 month ago. The feed rate will reduce about 30% whenever there is module G41 and G42. We tried run the same program on other machine (with 0i-MD controller), but it is working fine. We also tried inserting a simple G41 program and test run, the feed rate doesn't reduce either!
    So will override parameter 1710 or adding G8P1 help solve the problem ?
    Feb 2006
    1792
    In radius compensation mode, the specified feedrate is maintained along the part boundary. It would be different from the speed of cutter's center.
  1. xy cutting problem
    By melzer in forum Fadal
    Last Post: 08-25-2010, 02:27 PM
  2. Problem with 3d paths for cutting
    By vinot in forum Composites, Exotic Metals etc
    Last Post: 12-01-2008, 04:44 AM
  3. PVC cutting RPM, feedrate, bit style, etc.
    By Robot Dude in forum Glass, Plastic and Stone
    Last Post: 08-07-2008, 11:08 PM
  4. having problem with a part im cutting
    By rustamd in forum Mach Mill
    Last Post: 10-17-2007, 05:59 AM
  5. Groove Cutting Problem
    By pprichard in forum MetalWork Discussion
    Last Post: 01-18-2006, 03:53 PM
