586,104 active members*
3,377 visitors online*
    May 2010
    6
    Meldas L1 parameter changing
    Hy everyone!
    I have got a Nakamura, with Meldas L1 controller.
    I want to know how can I change the (maybe protected) parameters.
    On the second and third page of the parameter list, where there is some parameters about the servo x and servo z. I wanted to change theese parameters, because we made some modify on the machine.
    Can somebody say how can I change theese parameters (some other parameters are changeable, but what I need are not changeable.
    Thank you for the help.
    Hy,
    Matúz Tamás.
    May 2010
    6
    Re: Meldas L1 parameter changing
    I have the solution!
    We didn't turn on the machine for a while, and the batteries went dead.
    The machine parameters are lost. (I made a backup copy fortunately).
    After I turn on the machine, I could write all of the parameters. After I finished, the parameter edit locked itself again.
    So if someone need to change the parameters:
    1. make a copy from the parameters
    2. turn off the machine
    3. take out the batteries
    4. wait aprox an hour (there are some condensators)
    5. turn on the machine
    6. write back the paramteres (change what you want)
    7. turn off, and turn on again
    And done.
    I hope I could help.
    Tomasz
  1. Meldas 335M parameter!
    By Cole84 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 10-03-2023, 07:58 AM
  2. Meldas 64 Lubrification parameter
    By paulosoares in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-21-2016, 09:16 AM
  3. OKK MHA-400 MELDAS 83 LOSS PARAMETER
    By CNCTECHNOLOGY in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 12-06-2012, 11:32 AM
  4. System Parameter Meldas 335
    By raetschakarle in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-04-2010, 11:15 AM
  5. How to do Tool Changing on Mits MV-70E w/ Meldas 520
    By icnc in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-26-2007, 05:30 PM
