586,692 active members*
3,151 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Would this motor be more powerfull than my current one?
Results 1 to 8 of 8
    Apr 2005
    78
    My current motor is the stock 1/5hp 1.8amp 110v one on the Harbor Freight Micro Mill. It is rated at 2000rpm.
    The one i found is one from a jigg saw. It seems to have a variable speed control, and is rated at 3.7amps, 3500 rpm, and is brushed. I have no idea of what HP this translates to. Would this do better? Higher rpm and torque?
    Thanks - zAck
    Apr 2004
    439
    motor sounds around maybe 1/2 hp maybe little less
    sounds like it will work good,just make sure it had over heating protection . If you do long runs without being next to the machine
    Apr 2005
    78
    How would I know? There are just two wires going to the motor, + and -. Well, I will always be near, and check it often. I'll post a pic tommorrow morning.
    24223
    What other numbers do you have? voltage etc? If not, if you crank it up somehow up to 3500 open circuit and measure the voltage across the + - and multiply by 3.5 then divide by 746 which will equal HP.
    AL.
    Albert E.
    Apr 2004
    439
    oh only two wires... well then it's not the 120ac i was thinking it was hehe it might be allot smaller . Do what altheman said that will give you the true hp
    Apr 2005
    78
    I can't imagine it will get anymore than 18 volts, (i havn't measured yet.), it would be like .08 hp? I doubt that. The one on the mill now is just about the same size, and has less amperage. Will your calculations work for dc too?
    24223
    Quote Originally Posted by radicooldude
    With two wires + & - I assumed it was DC.
    If it is a universal motor then the previous procedure won't work.
    Al.
    Albert E.
    Apr 2003
    1873
    Dang it Al_The_Man,
    Is there nothing you do not know about motors ?
  1. How does a power supply work.
    By ynneb in forum DIY CNC Router Table Machines
    Last Post: 07-27-2011, 03:40 PM
  2. Stepper motor: voltage vs. current ratings
    By cnczane in forum DIY CNC Router Table Machines
    Last Post: 09-08-2008, 06:14 PM
  3. Can someone please explain "chopper drive"
    By stuart76 in forum Stepper Motors / Drives
    Last Post: 06-10-2007, 01:31 AM
  4. 5vdc from paralell port, not enough???
    By thuffner3 in forum CNC Machine Related Electronics
    Last Post: 11-23-2004, 01:07 PM
  5. Stepper question: torque re: current
    By cnczane in forum Stepper Motors / Drives
    Last Post: 10-22-2004, 02:30 AM
