586,075 active members*
3,937 visitors online*
IndustryArena Forum > Hobby Projects > Musical Instrument Design and Construction > Tutorial: Rhino, Cut3D, and Vcarve Pro to make a guitar body..
Results 1 to 16 of 16
    Aug 2009
    19
    well, I made a tutorial this week on making a guitar body using Rhino, Vcarve Pro, and Cut3D all together... mainly to show how to import the contours you create with Rhino into Vcarve pro and align eveything to work.. hope this will maybee help someone who has the same software..
    untill I figure out how to embedd the videos... heres the links:
    [nomedia="http://www.youtube.com/watch?v=f38EcZAPl4I"]YouTube- 2852010_106_50.avi[/nomedia]
    [nomedia="http://www.youtube.com/watch?v=rDuynIgqXos"]YouTube- 2852010_1030_46.avi[/nomedia]
    [nomedia="http://www.youtube.com/watch?v=M49DysZ59E4"]YouTube- 2852010_1222_17.avi[/nomedia]
    part 4 will be coming the next few days....
    Feb 2010
    Cool.
    My split with the contour failed when I did it so I moved the surface up an very small amount (so it remained as accurate as possible) and it worked
    I am not sure about your crazy sphere idea, as I don't think that the crossection of the bevel there would give a straight line (which it usually is for comfort bevels)
    Anyway KUDOS to u for making a tutorial video, I'll bet someone will find them helpful
    Can I request a carved top tutorial?
    Apr 2007
    8082
    Quote Originally Posted by konalure View Post
    Thanks very much! YouTube provides an embedded video link. Just copy the link and paste it into your CNC Zone post. It will let you pick a color and size for the video frame that will be embedded.
    CarveOne
    CarveOne
    http://www.carveonecncwoodcraft.com
    I think the site here is messed up. I tried to fix your post last night and it didn't work. Normally, you just copy the link and it's embedded automatically.
    Apr 2007
    8082
    Let's see if this works as a test:
    <object width="660" height="405"><param name="movie" value="http://www.youtube.com/v/f38EcZAPl4I&hl=en_US&fs=1&color1=0x006699&color2=0 x54abd6&border=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/f38EcZAPl4I&hl=en_US&fs=1&color1=0x006699&color2=0 x54abd6&border=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="660" height="405"></embed></object>
    CarveOne
    CarveOne
    Aug 2009
    19
    thanks for trying to fix that.. I first just copied and pasted the links but when I previewed the post I realised it didnt work, I thought I had done something wrong on my side and was going to try to figure out what I had done wrong today... good to know that it was something with the site and not me.. you saved me a lot of time not bothering with it..
    yea, the sphere thing makes for a pretty lame bottom contour.. mainly I just needed something fast for the tutorial in order to show how to setup the contours for Cut3D.. and then importing them into Vcarve Pro.. of course I know of a few guitarists with pretty big beer bellies so that contour might work well for them ( myself included ) ... :cheers:
    Apr 2007
    8082
    I guess not. Click on the Embed button and you will see a short list of options. Check the box for the options you want to enable. Then copy the embed code and paste it in your CNC Zone post.
    The embed code was supposed to display a green frame and border.
    CarveOne
    CarveOne
    Feb 2005
    168
    Konalure that was absolutely bloody amazing!!!!!!!!!!! I just wish i had an 1/8th of your skill,I'll be watching out for all your informative posts,keep up the good work bro "CHEERS!"
    Aug 2009
    19
    added the last segment to the tutorial..
    [nomedia="http://www.youtube.com/watch?v=0LnpbftHtg0"]YouTube- cncguitar3.wmv[/nomedia]
    wish I could embedd them all into the first post but maybee will get sorted out later..
    aloha,
    Del
    Feb 2005
    168
    Bro that turned out superb,well done on that my friend CHEERS!
    Sep 2007
    359
    Apr 2009
    144
    I had no Idea that it was possible to even import carve3d into vcarve!!
    Thanks a lot!
    JGRO Complete - G540, 380oz Nema23s, 1/2-10 ACME, 30"x14", Craftsman router
    Joes 4x4 R&P in progress
    Feb 2007
    6
    Nice tutorials, but I have a question. Could the entire guitar be cut with Cut3D from the Rhino file which includes the contours? Why is it necessary to use Vcarve as well?
    If you used Cut3D only, the entire body would be cut with a back and forth motion, the same as the contours are in the video. You'd probably need at least 2 passes, to avoid plunging the full thickness of the body at the perimeter.
    By using V-Carve Pro for the profile and pocketing, the machine time is probably 20% or less of what it would be if using Cut3D alone.
    Feb 2007
    6
    Thanks for the information. This is good to know.
    Aug 2009
    19
    Smile
    thanks for the comments and questions so far guys and thanks for answering beamhome's question ger21...
    the main reason I use the 2 programs together I'll add, is because if you only use Cut3D, the neck pocket, pickup pockets, and perimeter profile cuts come out very sloppy it seems.. I would never try to use Cut3D for making those cuts.. I really need to use a 1/4 endmill for those routes and it would not work well with Cut3D.....using Vcarve for pocketing those is a way better way to go.. plus, using both programs is a lot faster in the end ..for me developing this process was basiclly a work around to not having more expensive software that would machine selective contours on the guitar body and not try to machine the whole thing at once. Cut3d is definatetely not as good as Mastercam most likely, but I do find it simple, and a lot cheaper, and a good alternative for someone trying to start out with a budget..
    anyways, thanks to all who watched and to CNC zone for having the ultimate resource for us all to learn this stuff
    aloha, Del
  1. electric guitar body
    By woodman08 in forum Gorilla CNC Machines
    Last Post: 07-08-2013, 01:48 PM
  2. Carvewright a guitar body?
    By LiquidGuitars in forum Musical Instrument Design and Construction
    Last Post: 04-02-2010, 05:30 PM
  3. Rhino Video Tutorial - Create a Diamond Solid in Rhino
    By Robert Schutz in forum Rhino 3D
    Last Post: 06-02-2008, 07:58 PM
  4. RFQ - Guitar Body Carving
    By klaabu in forum Employment Opportunity
    Last Post: 12-19-2007, 02:19 AM
  5. Irregula Guitar Surface on Rhino
    By NCN in forum Rhino 3D
    Last Post: 03-24-2006, 06:20 PM
