586,106 active members*
3,020 visitors online*
    Dec 2005
    439
    Programing G200
    Anyone know of where I can find a discription on how to use G200 on a HASS? anything at all would help
    I'm not lazy..., I'm efficient!
    HAAS GR-408
    Jul 2005
    340
    have you tried the manual ?
    Code:
    G200 Index on the Fly (Group 00)
    U Optional relative move in X to tool change position
    W Optional relative move in Z to tool change position
    X Optional final X position
    Z Optional final Z position
    T Required tool number and offset number in standard form
    This G code will cause the lathe to change tools while performing a rapid move
    away from and back to the part, to save time.
    Example: G200 T202 U0.5 W0.5 X8. Z2.
    U and W specify a relative motion in X and Z, which is performed as the tool
    turret unseats. X and Z specify the position to move to as the tool turret reseats.
    Both motions are rapid.
    Dec 2005
    439
    I did look at a manual yes but the one I have on hand is too old I guess as I now looked at the one Haas has online and its in there.
    Thank you for your reply and as such turns out this isnt the code I was hopeing i to be. I am in need of a way to index the spindle no the turret its in a GT-20 so the travel is so short the G200 is of no use I was really hopeing it would allow me to cotrol an indexing of the spindle on the fly.
    HAAS GR-408
    Jul 2005
    340
    maybe you can make use of M19 ? or G05 ?
  1. Heidenhain iTNC 530 G200(pecking cycle)
    By DULING in forum G-Code Programing
    Last Post: 02-03-2011, 04:27 AM
  2. What are you using for Heatsinks for G200 drives
    By Wolfesmetalfab in forum Gecko Drives
    Last Post: 12-10-2008, 07:43 PM
  3. 0-M programing help please
    By venomgrrrl in forum Fanuc
    Last Post: 12-08-2007, 06:51 AM
  4. CNC programing
    By Fryzss in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-27-2007, 04:33 PM
