586,108 active members*
3,111 visitors online*
    Aug 2004
    218
    Thread milling on a CNC lathe
    Hi Guys
    Im setting up a Doosan 2000sy with a Fanuc 18i-TB control. The part beening machined has a cross hole which has a 9/16-18 thread in it. The problem Im having is how dose G41 work?? I need to be able to offset the threadmill in Z and Y axis bit by bit to maintain thread Dia. size. Here is the threadmill part of the program. I not sure where to place wear offset numers as needed.
    Thanks for all an any help guys
    (THREAD MILL)
    (TOOL-11 OFFSET-11)
    G54
    T1111
    G19G98
    M7
    G0X1.Z-1.1875
    G97S2000M33
    X.37
    G3X.3838Y.0392Z-1.1483R.0392F5.
    G41X.3978Y0.Z-1.109R.0392
    X.4256Y-.0785Z-1.1875R.0785
    X.4534Y0.Z-1.266R.0785
    X.481Y.0785Z-1.1875R.0785
    X.5088Y0.Z-1.109R.0785
    X.5226Y-.0393Z-1.1483R.0393
    X.5364Y0.Z-1.1875R.0393
    G1X.37
    G3X.3838Y.0405Z-1.147R.0405F5.
    X.3978Y0.Z-1.1065R.0405
    X.4256Y-.081Z-1.1875R.081
    X.4534Y0.Z-1.2685R.081
    X.481Y.081Z-1.1875R.081
    X.5088Y0.Z-1.1065R.081
    X.5226Y-.0405Z-1.147R.0405
    X.5364Y0.Z-1.1875R.0405
    G0X1.
    M35
    G40
    M09
    M90
    G28Y0.
    G28U0.
    T1100
    M01
    Feb 2006
    992
    Cutter comp turn on with G0/G1 only.
    The best way to learn is trial error.
    Mar 2006
    167
    Can't say that I have ever tried to use radius comp for milling on a lathe. Have you tried using a value in the radius offset with the current program?
    2932
    (THREAD MILL)
    (TOOL-11 OFFSET-11)
    G54
    T1111
    G19G98
    M7
    G0X1.Z-1.1875
    G97S2000M33
    X.37
    G1G41X.3838Y.0392Z-1.1483F5. <------ turn on comp w/ linear move here
    X.3978Y0.Z-1.109R.0392 <------ remove G41 here
    G1G40X.5364Y0.Z-1.1875 <------ turn off comp w/ linear move here
    G1X.37
    G41X.3838Y.0405Z-1.147F5. <------ turn on comp w/ linear move here
    G0X1.
    M35
    G40
    M09
    M90
    G28Y0.
    G28U0.
    T1100
    M01
  1. Thread Milling
    By Dadeslot in forum G-Code Programing
    Last Post: 03-29-2011, 12:42 PM
  2. 3M and thread milling?
    By teamjnz in forum Fanuc
    Last Post: 11-04-2008, 02:09 AM
  3. thread milling on lathe
    By Bigbill in forum Mastercam
    Last Post: 04-10-2008, 06:06 PM
  4. Lathe question: Thread milling vs. single pointing....
    By PoiToi in forum Uncategorised MetalWorking Machines
    Last Post: 02-22-2008, 02:24 AM
  5. Thread Milling on a 5 axis lathe
    By Jr. Programmer in forum G-Code Programing
    Last Post: 07-28-2007, 01:09 PM
