587,067 active members*
3,482 visitors online*
    Nov 2004
    436
    Exclamation Absolute encoders
    My yaskawa servos have absolute encoders. The documentation says that the SEN channel transmits absolute position in ASCII format. I think it transmits the position ever 40 micro-seconds (not sure what the mu symbol means) There is documentation on the parity, stop bits, flow, etc.
    I am using a Galil DMC-4080 motion controller, and running Mach 3 software.
    Does anyone know what would be required to capture the position signal, and get that number imported into Mach3 upon start-up? I can write the macro to move the data around in Mach3, but I am not sure how to get it in there in the first place.
    I want to do this with 4 separate servo encoder signals, to update the position on start-up. What kind of hardware would I need to handle 4 separate signals, and get them on my computer screen? Is there some kind of USB to terminal board available?
    Thank you in advance.
    Rob
    Nov 2004
    436
    The servos I have came stock with the Absolute encoders. It has a feature where the encoders can be used as either incremental, or absolute.
    Does anyone know how to capture 4 channels (4 encoders)' worth of ascii text, and get it into my computer?
    Rob
  1. Small multiturn absolute encoders/servos
    By Rhodan in forum Want To Buy...Need help!
    Last Post: 11-11-2009, 08:09 PM
  2. Absolute vs. incremental encoders
    By sinha_nsit in forum Fanuc
    Last Post: 10-11-2009, 10:38 PM
  3. Zero X axis absolute encoders
    By Cov Kid in forum Fanuc
    Last Post: 07-29-2009, 05:28 AM
  4. Absolute encoders?
    By REVCAM_Bob in forum CNC Machine Related Electronics
    Last Post: 04-21-2007, 04:26 AM
  5. Absolute encoders?
    By murphy625 in forum CamSoft Products
    Last Post: 03-29-2005, 04:18 AM
