586,121 active members*
3,804 visitors online*
IndustryArena Forum > CAM Software > SprutCAM > Engraving on a cylinder
Results 1 to 11 of 11
    Sep 2009
    318
    Trying to engrave this image/text on a cylinder. What is the best method do to this with? Everything I have tried always seem to have issues and/or I keep crashing Sprutcam.
    Here is my sprut file.
    DF4GRtext.stc
    Feb 2010
    I was looking around for something that could engrave and came up with this site that has tooling, software and is in Mass.
    There software does 4th axis engraving on cylenders , serial numbers imports jpg, bit, dxf, gif, and more and makes the g code..
    Here is the link
    http://www.2linc.com/engraving_software_overview.htm
    I am saving up to get a copy and there spring loaded engraving tool looks interesting..
    AirAmp
    May 2005
    2502
    BTW, the spring loaded engraving tools are not hard to make. Lots of threads around various places about them.
    Cheers,
    BW
    Try G-Wizard Machinist's Calculator for free:
    http://www.cnccookbook.com/CCGWizard.html
    Dec 2009
    48
    Quote Originally Posted by compunerdy View Post
    DF4GRtext.stc
    Hello compunerdy,
    Here is a YouTube video of how to use the Engraving operation in SprutCAM to accomplish your task.
    [nomedia="http://www.youtube.com/watch?v=ipMzouKZGko"]YouTube- SprutCAM 7 Cylindrical Engraving on a Solid model[/nomedia]
    You may also read the "Mill Machining->Operations Setup->Using design and machining features in Job Assignment->Using design features in Engraving/Pocketing operation" topic in the help.
    Sep 2009
    318
    Live, very cool demo..thanks
    I did get it to work after hours of trying different thing. One of the issues I had was when I set the base level at .8125 the N looking letters would get setup with lines wrapping around the part etc. I eventually changed it to .8126 and it all worked fine. I see now from your example that this could have been done 100 times faster lol.
    So once again... THANK YOU VERY MUCH!!!
    I think the issue was how many decimal points I was using so it was causing it to round.
    Dec 2009
    48
    Here is another example of rotary milling in SprutCAM7:
    [nomedia="http://www.youtube.com/watch?v=0-c3mRQltW4"]YouTube- SprutCAM 7 Rotary pocketing and swarf finishing[/nomedia]
    Jul 2004
    595
    Is it possible to use Sprutcam to engrave on a sphere, like what you might find on a gear shift knob?
    Dec 2009
    48
    Quote Originally Posted by David Bord View Post
    You can see an example in the SprtuCAM/Examples/5d_Milling/5ax_engraving.stc.
    Jul 2004
    595
    Quote Originally Posted by Live View Post
    thanks... Is it possible to do that with 3 axis? (not at home so cant check the project)
    David
    Dec 2009
    48
    David
    Yes it is possible.
    Jul 2004
    595
    Thanks, perfect! Is there any way to use sprutcam to project text onto a surface/sphere like you have in that tutorial?
  1. Engraving around a cylinder
    By musall37 in forum Haas Mills
    Last Post: 03-09-2010, 06:40 AM
  2. engraving around a cylinder G107
    By panaceabea in forum Haas Mills
    Last Post: 01-26-2010, 06:11 PM
  3. cylinder
    By copperhead4321 in forum Solidworks
    Last Post: 05-13-2008, 04:20 PM
  4. 4 cylinder
    By bluejets in forum I.C. Engines
    Last Post: 07-04-2007, 03:26 PM
  5. Replies: 1
    Last Post: 12-29-2003, 02:06 AM
