586,437 active members*
3,980 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > problem finish loading program to delta 20
    Apr 2010
    260
    I have my new mill up and running and I got my computer communicating with the Dynapath Delta 20 controler via the RS232. I can get the machine to load a program from the laptop, but when it gets to the last line of code the machine does not complete the program load and is still in the load program state. Is there a G or M code that needs to go at the end of the program to tell the controller the program has completed.
    Oct 2003
    102
    I had a similar problem when my communication settings weren't quite right. Its been a while, but I think the baud rate was set incorrectly. You might try slowing it down to see if that doesn't help. Also, to get your post better exposure you might try the dynapath forum.
    Apr 2008
    49
    I have no problem send and recieve to Delta10 and 20, the last line in the program there was a word "END" , and I'm using Winpro DNC as communication program
    Apr 2010
    260
    problem solved. I removed all the spaces from the posting as well as all the comments. After that the program loaded sucessfully.
    thanks
    Dan
  1. Loading NC program
    By data-matique in forum HURCO
    Last Post: 06-17-2018, 03:43 AM
  2. loading program
    By SELECT in forum Haas Mills
    Last Post: 08-14-2008, 12:31 PM
  3. Okuma MC-6V OSP 3000m Program loading Problem
    By ChrisProphet in forum Okuma
    Last Post: 09-13-2007, 11:21 PM
  4. Okuma MC-6V OSP 3000m Program loading Problem
    By ChrisProphet in forum DNC Problems and Solutions
    Last Post: 09-04-2007, 05:07 PM
  5. up loading a cnc program
    By fjd in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 11-06-2003, 12:34 AM
