586,061 active members*
4,463 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Fadal 4020 mystery chatter
Results 1 to 14 of 14
    Dec 2009
    21
    I am getting chatter during any change of direction (x,y) at any feed over 20ipm and nobody can seem to figure it out. The chatter is only for a split second after directino change them it will run smooth as glass. This machine would be perfect if I could only fix this issue. Its a 96 4020,dc motor, box way, 10k spindle, 700ipm rapid, 88hs control.
    Here is what we have done so far.
    -checked gains. they are good.
    -replaced x,y resolvers
    -replaced x,y gibbs
    -checked table flatness. within a couple thou.
    Anyone with any further ideas? Here are some pictures of the issue. This was 80ipm.
    Jul 2009
    317
    Check Spindle bearings preload; drawbar tension.
    Dec 2009
    21
    Both techs checked the drawbar tension and it was good.
    Jul 2009
    317
    It is Pozy belt driven or 6 belts?
    Dec 2009
    21
    two large belts. one for high one for low. just replaced belts and cleans entire assembly yesterday before rerunning part in pic.
    Jan 2004
    3154
    How about XY thrust bearings
    www.integratedmechanical.ca
    Dec 2009
    21
    Quote Originally Posted by DareBee View Post
    they were check by the first tech who also replaced the gibbs.
    Sep 2009
    181
    Did this problem start occurring recently or has it always happened? Did you make any changes prior to the chattering?
    Need help with your Fadal? Send me a message or visit www.TheFadalParts.com. We have over 25 years of experience at Fadal and offer FREE TECHNICAL SUPPORT OVER THE PHONE!
    Dec 2009
    21
    Quote Originally Posted by iess525 View Post
    its been like this for a years, but things have been so slow till recent that i just delt with it. during these years i've had multiple tech come in, diagnose and fix everything but the chatter.
    Sep 2009
    181
    Can you send me your phone number? I will do my best to help you out and we can post the results here to help anyone else who may be having this issue as well.
    Feb 2005
    376
    My 2 cents, take it for what its worth.
    Looks like a deflection issue, where you are getting the gouging is where the cutter goes from having more material to cut to less material to cut. Also look at your witness marks, they clearly show that you are deflecting as you circle the part, and it also looks like your head is a bit out of square tilted a bit towards X positive.
    I'm running pretty close to the same path you are right now in 13-8, I'm showing only the leading edges of the endmill all the way around(deflection), I'm running .400 deep, .300 wide with a half inch endmill, square corners.
    The corners are just showing a pattern overlap, no gouging, with that info...
    My diagnosis is Z axis thrust bearings.
    What material, chipload, we already hit feed, depth of cut, endmill, tool holder?
    I'll take another guess, it looks you are feeding about 15% of your diameter per rev, and your tool is either running out or dragging a chip.
    Interesting problem
    Jan 2004
    3154
    Or gibs set too loose on Z.
    Mar 2006
    127
    Are you rolling the cutter around corners or just slamming it into a 90 degree turn? If it's engaging a decent amount of material, then I could see it getting pretty angry about an instant-turn.
    Nov 2005
    41
    machine is not anchored into concrete
    feed rate too high for the directional changes
    causing machine to shake (bounce)
    program radi in corners problem goes away
  1. Fadal 4020
    By joshuac in forum Fadal
    Last Post: 09-10-2010, 11:36 AM
  2. FADAL 4020 Z-AXIS WON'T GO!
    By TRACYPFAB in forum Fadal
    Last Post: 05-27-2010, 02:44 PM
  3. 96 Fadal 4020 TurboCadCam
    By ThatguyDave in forum Fadal
    Last Post: 08-28-2009, 07:27 PM
  4. FADAL VMC 4020
    By dmac88 in forum Fadal
    Last Post: 05-18-2009, 08:45 PM
  5. How do I tell the age of a FADAL 4020?
    By Rickady in forum Fadal
    Last Post: 07-10-2007, 12:02 PM
