587,006 active members*
2,795 visitors online*
Results 1 to 8 of 8
    Apr 2007
    10
    Anilam Crusader 2 controller
    i am looking at purchasing my first milling machine, it is a 1986 mill port knee mill with anilam crusader 2 controller. i have a diploma in machine tool tech and am comfortable using canned cycles and g-code. i have done a little reasearch and found that this controller can be repaired here: Lynn Electronics Corporation
    has anyone had any experience with this controller? is there a good chance i will have problems with a controller that old? the asking price for this machine is $5500, does this sound reasonable? thank you.
    10" X 50" table
    Vertical head swivels
    Variable speed: 60 to 4250 RPM
    R8 spindle taper
    Anilam Crusader II CNC controls
    Two Axis contol X travel 31.5"; Y Travel 14"
    Bijur lube system
    Spraymist coolant system
    Miscellaneous tooling; Two collet racks; 6" swivel vise
    Apr 2007
    10
    still looking at this machine any help is apperciated
    Apr 2007
    10
    bump
    Mar 2009
    1982
    what help do You expect?
    It's Your decision. Is it investment or hobby or maybe money making machine ...
    Nov 2010
    mmmmm.....
    Jan 2007
    16
    I just got a mill with Crusader II controller and will scrap it for a Mach 3 controlled system. The Crusader II was great technology for the 70's when it was designed but there are better options now.
    Sep 2009
    64
    That is way too much for that machine !!!
    JMO but not worth more than $2000
    Apr 2007
    10
    thank you for the replys, i was worried about the old controller, i decided against buying that machine.
  1. V20 With Anilam Crusader II
    By harvard5 in forum BobCad-Cam
    Last Post: 09-24-2011, 01:55 AM
  2. Using G92 in Anilam Crusader M controller
    By Rot Iron Racer in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-16-2008, 04:26 AM
  3. Anilam Crusader II - Crusader 2 Training DVDs
    By Mike Mattera in forum News Announcements
    Last Post: 07-09-2007, 03:31 AM
  4. Anilam Crusader 2 Help
    By plascom in forum Uncategorised MetalWorking Machines
    Last Post: 01-23-2005, 11:10 PM
