586,308 active members*
3,782 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > Milling Aluminium with a high speed router
Results 1 to 10 of 10
    Feb 2010
    Hi guys,
    Is there any guide to milling aluminium with a high speed router? I have a CNC router from RoutoutCNC but the routers minimum speed is 10,000 rpm. As I understood it you need to mill metals at much slower speeds. I plan to use a 4mm steel with Ti coating 4 flute end mill. Any help would be appreciated.
    Jul 2005
    12177
    4mm diameter will be fine at 10,000 rpm, you could even go faster. Just use coolant/lubricant and preferably a two flute cutter to give better chip clearance.
    Feb 2010
    Thanks for the reply, any idea on approximate feed rates?
    Apr 2006
    3498
    SPindle RPM: 24243
    Cut Feed= 484IPM
    for the mentioned cutter... At 10000you can CUT at 150IPM..
    PS:
    Don't act on my figures you can loose the endmill
    http://free3dscans.blogspot.com/ http://my-woodcarving.blogspot.com/
    http://my-diysolarwind.blogspot.com/
    Jul 2005
    12177
    With a cutter that small only about 0.2% to 0.4% of the cutter diameter is safe, depending on your depth and width of cut. That gives around 2 metres per minute feed; which seems fast so maybe go a bit slower.
    Apr 2006
    3498
    for DOC i will suggest you to use value of=1/4 x dia of cutter.. in your case it comes out 1mm....
    Nov 2004
    436
    Use WD-40, and listen to the router. If the tool clogs up, you will notice a slight change in the sound. Stop cutting, and clean the tool. Aluminum seems to melt/smear onto the carbide. Once clogged, it will break off.
    Rob
    Apr 2006
    3498
    Also use helical or ramping entry..do not plunge directly.. we want to save You, your tool, machine , workpiece and offcourse our time for after-effect discussion
    Best of Luck
    Feb 2010
    Thanks very much for all your help guys!
    Mar 2009
    163
    i router aluminum with 3/16 end mill at 18000 rpm 1000mm/m single oflute onsrud bit 63 series, 1/16" doc
    i find on our machine anything more than one flute seems to plug up and is not suitable for production type work, we also have a air mister.
    __________________________________________________ _________________
    http://www.cnczone.com/forums/showthread.php?t=86985 my work in progress
  1. Milling a high speed spindle mount
    By Jay C in forum Videos
    Last Post: 08-16-2008, 05:34 PM
  2. High speed spindle for milling
    By thackman in forum Benchtop Machines
    Last Post: 12-19-2007, 07:24 PM
  3. High Speed CMS FOAM 5-axis milling machine
    By fairlane77089 in forum Hard / High Speed Machining
    Last Post: 06-05-2006, 04:09 PM
  4. High Speed Hard Milling
    By MachineSMM in forum Hard / High Speed Machining
    Last Post: 03-28-2006, 01:31 AM
  5. High-Speed 3 (4?) axis cnc router
    By rherman in forum DIY CNC Router Table Machines
    Last Post: 10-21-2005, 04:31 AM
