586,052 active members*
4,323 visitors online*
IndustryArena Forum > Mechanical Engineering > Mechanical Calculations/Engineering Design > how to calculate the cutting force for a rough end milling operation
    Jun 2010
    Question how to calculate the cutting force for a rough end milling operation
    Can anybody suggest how to calculate the cutting force for a rough end mill operation?
    It would be helpful if one can provide the formulae (in metric units) for rough end mill operation.
    It is very urgent. Thanks!!!
    Feb 2009
    2143
    Not sure if you specifically need the forces, or just machine settings. If that latter, this is a great tool to use:
    http://www.cnccookbook.com/CCGWizard.html
    Jun 2010
    Question how to calculate the cutting force in rough end mill operation
    I would like to know how to calculate the cutting force exerted by the end mill cutter on the work piece during rough machining process.
    Please suggest me the formulae to calculate the cutting force.
    Feb 2009
    2143
    I think you are asking the uncalculable. Just a slight difference in the sharpness of a tool will change the force tremendously.
    Nov 2005
    160
    IIRC there are equations in some manufacturing engineering text books to calculate that. I'm sure they are loaded with emperically derived constants that probably go out the window when the cutter gets dull, as mentioned. I'll take look tomorrow at the office.
  1. Cutting Force During Milling
    By KyleL in forum Mechanical Calculations/Engineering Design
    Last Post: 09-22-2010, 03:52 PM
  2. Milling Force Calculation
    By diabolical7 in forum Mechanical Calculations/Engineering Design
    Last Post: 07-19-2009, 07:27 PM
  3. How to calculate cutting forces
    By Swiss in forum Hard / High Speed Machining
    Last Post: 04-24-2009, 07:05 PM
  4. Down force from milling cutters
    By BillTodd in forum Mechanical Calculations/Engineering Design
    Last Post: 12-04-2008, 02:12 AM
  5. force applied to table ? is there an easy way to calculate it ?
    By jimtom in forum Mechanical Calculations/Engineering Design
    Last Post: 06-06-2007, 03:36 AM
