586,103 active members*
3,185 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc 0M G84 (tapping) doesn't work anymore..
Results 1 to 10 of 10
    Jun 2010
    Cool Fanuc 0M G84 (tapping) doesn't work anymore..
    ***Problem solved, I had the machine turned on all night and the next morning G84 was working again, No changes made to the code or to the machine, It just worked again, The problem is a faulty mainboard***
    Hey fellow CNC-folks!
    I've got an old Johnford VMC-416 mill (1986?) with Fanuc 0M as controller,
    So my big problem is what the title says, G84 has completely stopped working, I get Alarm 014 as soon as the machine is about to start tapping, The code looks exactly the same as it did when G84 worked. When i check the Alarm 014 in the manual supplied by Johnford it says something about the K-value being too high of what's allowed, However, I don't use a K-value and i haven't done it before either (The k-value can be used when you use G91 for repetations or something like that, but i use G90 so i shouldn't have to use the K-value at all, and as i said, It worked just fine before), However i did try using the G91 version with a K-value in the tapping code but with the same result.
    I've searched the net for a possible fix but it doesn't help that much, My assumption is that a system parameter has been changed or something is wrong with the board, The later is what i suspect because i haven't touched the system parameters ever and they seem to be intact, But with these older machines you never know
    Some misc information:
    -M29 does nothing (Seems like some newer controllers need this code to be able to start tapping)
    If i check the G-code list in the machine there's a G63 called "Tapping mode"
    G63 is used for tapping in Fanuc 21 if im not wrong?
    "N...G63...Z...F"
    Just for the hell of it i tried using G63 but nothing happens, No alarms, no nothing so i got no clue why it's included in the machines G-code list.
    Anyone been through this before and know what i need to do? The tapping is the last operation on my parts and i'd rather not have to tap 250 holes manually, hehe
    Oh yeah, I've done the "shut down the machine completely, wait a while, Start and try again-part" a dozen times and it doesn't work either,
    I'd be really thankful for some help here
    2932
    Maybe if you posted the section of code where the error occurs...
    Nov 2007
    28
    tapping problem
    Hi Chopit
    Make sure you are using G94 feed per minute, and not G94 feed per rev.
    Jun 2010
    Quote Originally Posted by dcoupar View Post
    As i wrote in the first post there's nothing wrong with the code that's why i didn't include it, This is/was a hardware failure because this morning it was working again without any changes made to the program or to the machine, I even kept the machine turned on all night.
    Quote Originally Posted by jlavery View Post
    Hi Chopit
    Yeah, That's the only feed option i can use with this old machine, G95 doesnt even exist
    Ah well, Thanks anyways guys
    May 2009
    181
    turn dry run on and see if it works that way..
    Jan 2010
    99
    couple things to check...
    other parameters can affect how your code will be interpreted... so make sure you are using the same as before the problem appeared:
    increment system A B C...
    g-code system A B C (may change your arguments from decimal/nodecimal values)
    decimal point input
    macros overriding any g-codes
    option parameters for rigid tapping is required as well... if you can check your 900 params...
    also, M29 does nothing apparent but it does something in the background (sync's the spindle and axis for rigid tapping) and usually requires an S### argument... and may or may not orient the spindle for you
    feed/speed overrides could be pushing the tap speed outside the max rpm for rigid tapping
    good luck
    - gwarble
    2932
    Is your code a secret? Perhaps if you posted it here someone could help.
    Jun 2010
    No, the code is not a secret, But since it's a simple cycle code i don't see any point in posting it. Here you go anyway:
    :6367
    (**** TAPPINGM12 ****)
    G00 G17 G21 G40 G49 G80 G90
    G91 G28 Z0 X0 Y0
    T3 M06
    G00 G17 G90 G94 G54 X0 Y0 S300 M03
    G43 H3 Z15 M08
    G00 X8.0 Y-25.0
    G00 Z10.0
    G84 G99 Z-21.0 R5.0 F514
    G80
    G00 Z20
    G00 G17 G90 G94 G55 X0 Y0 S300 M03
    G43 H3 Z15 M08
    G00 X8.0 Y-25.0
    G00 Z10.0
    G80
    G00 Z15
    M09
    M05
    G00 G91 G28 Z0.
    G28 X0. Y0.
    G90 G80 G40 H0
    M30
    And for a third time, It's working again, read the first post for more information.
    2932
    Never thought to look at your original post to see that it was solved. Sorry to have bothered you.
    Jun 2008
    1511
    LMAO. Dave you crack me up.
    Stevo
  1. Fanuc OTC rigid tapping help
    By 47MLB in forum Fanuc
    Last Post: 03-07-2010, 06:24 PM
  2. Tapping using G84 on Fanuc 3M Controller
    By EDL at AU in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-25-2010, 10:33 AM
  3. Fanuc OM tapping prolem
    By glovebox20 in forum Fanuc
    Last Post: 01-22-2010, 05:59 AM
  4. Fanuc 6T-B tapping cycle?
    By party o one in forum Fanuc
    Last Post: 09-19-2008, 05:20 PM
  5. Help! It doen't work anymore?
    By boxwood in forum DNC Problems and Solutions
    Last Post: 08-04-2003, 06:29 PM
