586,033 active members*
3,099 visitors online*
    Jun 2010
    RZNC 0501 Plasma on/off
    Using the RZNC 0501 controller on a plasma cutting machine.
    What g-code is used to turn the plasma on and off?
    The actuator that sends the head down to the work piece seems to turn on at x,y=0,0 and then stays on untill the code has finished running
    Is there a setting within the controller that says whether or not the machine will read inputs to control the actuator?
    May 2011
    I have same problem . How do you resolve this problem .
    Jan 2007
    599
    is there any sample code in the handheld pendant that you can run to see if it works with that?
    May 2011
    N0000 (Filename: plzdeneme.nc)
    N0010 (Post processor: Mach3 plasma.scpost)
    N0020 (Date: 13.09.2013)
    N0030 G21 (Units: Metric)
    N0040 G53 G90 G91.1 G40
    N0050 F1
    N0060 S500
    N0070 (Part: plzdeneme)
    N0080 (Operation: Inside Offset, 0, T4: Plasma, 1.5 mm kerf)
    N0090 M06 T4 F5000.0 (Plasma, 1.5 mm kerf)
    N0100 G00 Z1.0000
    N0110 X5.7500 Y5.7500
    N0120 M03
    N0130 G04 P2
    N0140 G01 X104.2500 F5000.0
    N0150 Y104.2500
    N0160 X5.7500
    N0170 Y5.7500
    N0180 M05
    N0190 G04 P1
    N0200 G00 X24.2500 Y55.0000
    N0210 M03
    N0220 G04 P2
    N0230 G02 X24.2500 Y55.0000 I30.7500 J0.0000
    N0240 M05 M30
    This code is sample but for spindle control . My problem , code M05 plasma don't stop .
  1. RZNC-501 host program
    By arzie2000 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-30-2023, 01:02 PM
  2. Problem with DSP controller RZNC 0501
    By oncoarse in forum Commercial CNC Wood Routers
    Last Post: 01-23-2023, 01:08 AM
  3. Precision Plasma LLC 6" rotary chuck for CNC plasma cutting
    By rchacich in forum News Announcements
    Last Post: 05-26-2010, 06:57 PM
  4. Chinese RZNC-05 controller & spindle help?
    By Metalmog in forum Commercial CNC Wood Routers
    Last Post: 05-25-2010, 05:20 AM
  5. RZNC-D5416 (zhb275) controller problem
    By coco.han in forum DNC Problems and Solutions
    Last Post: 08-20-2009, 01:36 PM
