586,103 active members*
3,362 visitors online*
    May 2010
    Enroute 3 help
    I purchased a used cam tech router (spacemaker) has enroute installed. The machine did not come with any manuals or product information. Does anyone have a manual or information in PDF?
    May 2005
    101
    Hello
    I am new with Enroute. I would like to create output file as G-Code. What driver I have to select ? Can any one help me please.
    Thanks.
    Nov 2010
    85
    VS Hester,
    Although Cam Tech calls their software something else, they nearly all ran Wincnc.
    The driver that you want is the cncctrl09 or Wincnc04. Neither one are part of the EnRoute package. I'm including cncctrl09. The post processor belongs to Microsystems World CNC. MicroSystems World CNC - PC Based CNC Controller - WinCNC CNC Software - CNC Controller Software - WinCNC - CNC Motion Control - "Home". If you have problems installing it, I think they can help you, but they will probably charge you a small fee. They really know their stuff. Of course they should, they wrote the post.
    muqtadir,
    It all depends on what type of machine you are using. If your controller is Wincnc, you can use this post also. If it is something else, you'll need a different one.
    Hope this helps,
    Butterknife.
    Attached Files Attached Files
  1. Enroute Pro 4
    By Grant Nicholson in forum Uncategorised CAD Discussion
    Last Post: 01-26-2012, 03:34 PM
  2. Hi New to CNC & Enroute
    By CNC Oz in forum EnRoute
    Last Post: 01-04-2010, 09:22 AM
  3. I use Enroute
    By DIY'er in forum EnRoute
    Last Post: 09-21-2009, 10:16 PM
  4. Enroute anyone?
    By trooper55 in forum Uncategorised CAM Discussion
    Last Post: 05-26-2008, 03:58 PM
  5. Anyone using Enroute
    By cncadmin in forum Uncategorised CAM Discussion
    Last Post: 05-28-2003, 06:08 PM
