Hey Norm,
I am not sure how the Hobby grade machines work, and if that have advanced set up parameters.
In the more advanced industrial CNC's (Hypertherm, Burny, MG etc) you can reduce your lead out to as little as Zero length. As soon ad your part drops you want the arc to shut off.
If you leave it on after the part drops, the arc will attach to the outer part of your piece and continue to cut until the Arc shuts off, or you streach the arc too far.
You can actually program a negitive leadout.
This stops the torch before the end of the cut.
This is for torches that require a second or two to shut off.
The PowerMax 1000 shouldnt need this feature.
This is also why you do not finish the cuts. The part drops out and the arc goes out befor the end of cut.
The machine stops and requires a Restart to continue.
If your CNC has a parameter 'Arc Off Time' that lets the machie run a given time after loosing the arc, this will help with the Restarts, but will not help the extra cutting done at the end.
This is what I call 'Programming Choreography'
It takes a little practice to get it working right.
Good Luck,
Alan Bradford
www.plasmatechnologies.com
