586,103 active members*
3,304 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc 11m parameter write protect
Results 1 to 3 of 3
    Apr 2009
    11
    I have been searching on here on how to unlock the 8000 parameter so that I can change other parameters. One other note, the edit mode does not work either. The write protect switch is enabled, and I check the connections to it. I can background edit, but not in regular edit mode. I just got the machine a couple of weeks ago. I looked and found a switch on the main board, but that did not work. Thanks for the ideas,
    Brian
    Jun 2006
    7
    Press EMERGENCY STOP button. Press "SETTINGS" softkey twice to get "SETTING(SETTING)" screen.
    Type in "8000" then press "INP-NO".
    Parameter number 8000 should appear on the screen.
    Type "10000001" and press "INPUT". Alarm " SW000 PARAMETER ENABLE SWITCH ON " will appear.
    Apr 2009
    11
    That worked, I got the parameters changed and that fixed the other problem. Thanks a lot.
  1. Replies: 8
    Last Post: 04-30-2010, 11:54 AM
  2. Fanuc OT parameter(s)
    By erwin1958 in forum Daewoo/Doosan
    Last Post: 03-27-2009, 04:36 AM
  3. FANUC 15T Write Protect
    By bmlw in forum Fanuc
    Last Post: 10-11-2008, 08:47 PM
  4. Parameter write enabling on Fanuc OiT
    By hense in forum Fanuc
    Last Post: 06-02-2008, 11:26 AM
  5. L50 parameter write
    By Bluesman in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-09-2006, 12:49 PM
