586,119 active members*
3,558 visitors online*
IndustryArena Forum > Manufacturing Processes > Safety Zone > Wiring Limit, Home and E-Stop Switches
Results 1 to 20 of 54
Threaded View
    I found this diagram, mentioned in an old thread, that seems to be a good way to wire up limit, home and E-Stop switches.
    My question, is if I can just put the E-Stop switch in series with the limit switches and free up a parallel port input? I assume so.
    Also, should the home switches be in the same location as X--, Y-- and Z++ limit switches or offset from each other?
    I am using Mach3, if that matters.
  1. Wiring Saftey Stop and limit Switches
    By jandalaser in forum CNC Machine Related Electronics
    Last Post: 06-12-2010, 08:05 PM
  2. Replies: 33
    Last Post: 02-24-2010, 10:39 PM
  3. Wiring Home and Limit Switches Efficiently
    By MrAR15 in forum Taig Mills / Lathes
    Last Post: 07-11-2009, 06:44 PM
  4. Wiring home and limit switches
    By Hack in forum CNC Machine Related Electronics
    Last Post: 01-24-2009, 10:47 PM
  5. Limit, Home and E Stop Switches
    By Mr.Chips in forum CNC Machine Related Electronics
    Last Post: 01-17-2007, 04:02 PM
