586,123 active members*
3,202 visitors online*
Thread: 5 axis help!
Results 1 to 9 of 9
    Nov 2009
    7
    5 axis help!
    hey ppl,
    im having problems trying to post 4 and 5 axis, im using mastercam x. I have a full 5 axis post for a dmu 50 evo. The post was done for mc9 and im trying to get it to work for mc x. Im trying a simple program eg drill at x0, y0. Then move to B+90 drill and then b+90 C+180 and drill. Im unsure where im going wrong, it looks ok on mastercam but then when i post it fails to output B or C moves. it just states them as 0 in the nc file. for example if the correct code should be B+90, x0 y0 then the cycle it just states B+0, x0 y0 then the cycle. would it have anything to do with the machine def in mcx?
    Jun 2009
    99
    It is my understanding that if you had a custom post made for version 9 that it will not work in version X.
    Nov 2009
    7
    well im not sure, it works ok in 9 but when i used the update post feature it doesn't seem to have worked. But in the .txt file that is produced when you update a post it stated that some features were not found so were set to 0. but when it comes to posts i dont have a clue.
    Sep 2008
    111
    Send me your .pst, .psb, .control, and .mmd files. I will take a look at it for you. what version of X?
    Nov 2009
    7
    do you have an email i can send them to? also i cant seem to find a .psb file for some reason. only the generic ones
    Sep 2008
    111
    PM sent
    Jun 2010
    If your post was for MC9. Did you ren update dll?
    Nov 2009
    7
    yeah, i run that in mcx. but it doesnt seem to have worked correctly.
    Jun 2010
  1. the Difference of 2-Axis and 3-Axis of Vertical Mill Machine
    By begacon in forum Knee Vertical Mills
    Last Post: 07-30-2009, 12:31 PM
  2. post for 2 axis ez trak versus 3 axis ez vision
    By tooolman in forum G-Code Programing
    Last Post: 11-28-2008, 10:33 PM
  3. Compare Catia and MCX2 for multi axis lathe/4 axis mill
    By bob1112 in forum Uncategorised CAM Discussion
    Last Post: 10-11-2008, 01:15 AM
  4. One axis (z-axis?) computer controlled testing device
    By TsThorsell in forum Stepper Motors / Drives
    Last Post: 02-07-2008, 07:38 PM
  5. New Design - Hybrid 3-Axis Router/4-axis Foam Hot Wire Cutter
    By the__extreme in forum CNC Wood Router Project Log
    Last Post: 02-26-2007, 09:58 PM
