Lots or just a few.
ABS plastic can be quite abrasive.
If you just have small quantity high speed steel is OK otherwise solid carbide cutters will last the distance.
You will get a better finish if you DON'T climb mill.
The rubbing action of the convention milling gives a nice burnished finish.
If you want to run fast coolant is a necessity to stop the ABS melting with the heat generated. It is bad conductor of heat so the cutter can get hot enough to melt the stuff.
