I am getting ready to buy & CNC an RF45 but need to be sure of all the bits needed before I pull the trigger. I plan to swap out the motor for a VFD controlled better quality motor. Nothing has been ordered yet. I do not have 3 phase power available. I have to date selected the Hitachi SJ200-015NFU VFD which converts single phase to 3 phase and controls speed, and a 3 phase Leeson motor. Depending on which version of the RF45 I buy it will come with either a 1.5 or 2 HP motor. Various posts on here suggest the VFD & opinions vary regarding using a 2 or 3 HP 3 phase motor.
Part 1
I did my best to search for the information I need and have read this forum until my eyes crossed and searched the internet as well. I have read that when powering a 3 phase motor with 1 phase through a VFD that
- the motor HP is reduced by 20%
- or the HP is almost at the nameplate rating up to the nameplate speed rating and at speeds over the rated level the HP drops dramatically or
- the HP at low rpm is reduced by as much as half.
So generally what is the real story? Should I spend the extra money to buy a 3 HP motor and VFD or will the 2 HP suffice?
Part 2
I am still confused about the electronics.
Based on what I have read, I plan to use:
- 1125 oz NEMA 34 servo motors 90VDC/40A
- US Digital: E5-500-250-N-S-E-G-2 Shaft-Mount Optical Encoder 500 CPR
- gecko 320X - one for each axis
- Honeywell Limit Switches SZL-VL-A
- Mach 3
This is where I get confused. I want to fully isolate my computer from the controller, control the VFD while protecting the CNC control, control a pendant, and many of the breakout boards have identical descriptions. One pdf manual said that if you connect the gecko then you lose isolation. A lot of these boards look like general purpose interface boards for many different types of uses.
- C11 - Multifunction CNC Board
- C11G - Multifunction CNC Board (for Geckos)
- C11T - Multifunction CNC Board w/Driver Control
- C23 - Dual Port Multifunction CNC Board
- smooth stepper USB SS1 contoller
- C25 - Smooth Stepper Terminal Board
- C1 - Parallel Port Interface Card
Then the C11's, the C23 and the smooth stepper board all have safety charge pumps and variable speed control, yet I have read where a C4- Safety Charge Pump and/or a C6 - Variable Speed Control Board is needed. I have read where a smoothstepper motion control was added to a C11.
Don't forget about all the different wiring diagrams posted by different people. Nearly 10 years ago I started to build a CNC mill and the state of information has not improved all that much. Too much is written by non English speakers which just make a complicated issue worse.
So - What combination of these boards do I need? Which additional boards should I consider? and why?
I appreciate all the assistance that members here provide, I have learned a great deal and once my project is completed I will share my results here.
