I am upgrading the servos on my system. My previous servos had an 8mm bore and 3mm keyway. The shafts on my new servos require a 14mm bore and a 5mm keyway. I have been searching for nearly a month to find a source for pulleys. I took the current pulleys to a local machine shop but he's charging me $130 to bore out 2 pulleys and keyways. He said he didn't have a 5mm broach so I guess I would be buying that for him. I would think you could replace all the pulleys and belts for that much. I am stuck without these.
Does anyone have a source for pulleys? I've checked McMaster-Carr and the typical sources.
