Originally Posted by
Martcnc
I just get tired of puzzling and redoing those program, which running from roughing route or utility to g-code into post programming.
Normal g-code program; (actual lathe motion)
G00 Z.12 X2.9 (feedrate in rapid to position)
G01 Z-3.9662 X2.9 F10 (feedrate @ 10 IPM)
G01 Z-3.9592 X2.9141 (feedrate @ rapid, instead of 10 IPM)
G00 Z.12 2.9141 (feedrate @ rapid)
G00 Z.12 X2.86 (feedrate @ rapid)
G01 Z-3.9545 X2.86 (feedrate @ rapid, instead of 10 IPM)
G01 Z-3.9475 XX2.8741 (feedrate @ rapid, instead of 10 IPM)
........ {"continue"}
I had to redo all program above with additing F(rate) for each G01, see below;
G01 Z-3.9592 X2.9141 F10 (feedrate @ 10 IPM)
G01 Z-3.9545 X2.86 F10 (feedrate @ 10 IPM)
G01 Z-3.9475 XX2.8741 F10 (feedrate @ 10 IPM)
Is anyone able to help me with camsoft configuring or setting for those post processing with my AS3000 or cncsetup?
Need to keep feedrate in G01 memory until notify any different feedrate in g-code to update changing G01 memory. It will save my time.
