586,477 active members*
3,730 visitors online*
Page 1 of 3 123
Results 1 to 20 of 52
    May 2005
    1662
    building a dust shoe
    Question: The router has a built-in fan to blow dust away from the work. Should the top plate of the shoe have a hole as large as the router diameter, allowing the router to blow into the shoe ? OR should this air be exhausted outside the shoe ?
    Question 2: If the inlet to the vacuum is small (2" ?, thinking about a dust deputy), is there any good reason to use a larger hose or inlet at the shoe end ?
    Anyone who says "It only goes together one way" has no imagination.
    1) I know a lot will disagree, but I prefer the air blowing down on the part. A properly designed shoe should keep all the dust in, and the air will help to ceap the chips out of the cut. In fact, my next router will have additional compressed air blowing on the cut to clear the chips.
    2) No, it will decrease performance. Imo, though, a 4" dust collector will work a lot better, and is a lot quieter.
    May 2007
    380
    The suction CFM needs to exceed the CFM of the router motor cooling fan. Otherwise, saw dust will be left behind.
    It would be nice to see a good side by side comparison of the two designs, with pros and cons of each type.
    John
    Sep 2009
    160
    My dust shoe clamps around the router...does reasonable well, but still doesn't blow all the chips out of narrow cut paths. The outlet of the shoe should match the diameter of the hose of your dust collector - putting a larger outlet will only slow down the velocity of the outlet air. A dust collector with a four inch hose will certainly work better than a dust deputy and a two inch hose.
    May 2005
    1662
    Hmmm, 2 thumbs down on the small diameter and I know you guys are talking from experience. Dust deputy has a larger cyclone for more $ and it's a fair guess (?) that the cost of the rest of the system goes up in proportion. This may come down to a pocket book compromise unless someone has a suggestion for flowing large air for relatively small money.
    Find a coupon for a 2HP Harbor Freight Dust Collector for $139. They're in several woodworking magazines, and I've heard they're good until September or October.
    I got one about 6 months ago. I use an older 1HP dust collector with my router, and the HF with my other tools. The Harbor freight has tremendous suction, and is far and away the best bang for the buck you'll find.
    Check Wood Magazine, American Woodworker and This Old House magazine.
    Sep 2009
    160
    I also use a Harbor Freight 2 HP dust collector. It uses 4 inch pipe and it really sucks (in a good way).
    Feb 2010
    61
    I have to vote for the 4" hose also. I tried the 2" route and found that there was not enough suction to pull up everything..the result was crud bouncing around the cutter while it tried to work.
    A couple of pictures of my DiY setup:
    Not an original design, I saw it on Youtube and made my own.
    May 2007
    380
    Not an original design, I saw it on Youtube and made my own.[/QUOTE]
    But you did answer a couple of questions. Sucking up the router motor exhaust with the dust can be done, but it does need the CFM volume of a 4" collector.
    John
    Feb 2010
    61
    I should clearify something, the 4" hose is connected to a 3ph Jet dual bag 1900CFM vacuum system. I doubt that a router can move as much air as even a good shop vacuum. I believe that the benifit of the larger hose is to deliver the full measure of CFM all at once to lift larger pieces out of the way immediatly (this,unfortunatly includes parts that you do not intend to have removed...really gotta make my tabs larger, lol).
    Jul 2009
    140
    My first dust shoe was a 2" diameter vacuum brush sealed to the underside of the router/router mount, with a 1-1/4" fitting for the vacuum hose. Much of the air blowing through the router actually went up the pipe, and the air draw from the vacuum probably improved the airflow through the router body. Trouble is, very little air flowed up through the brush, so performance sucked. Also, it wasn't possible to change bits without first removing the dust shoe.
    I'm now using a more traditional skirted shoe with 2-1/2" hose. I've found that this works a bit better, since the skirting does help contain dust, but at the same time, the downwash from the router does seem to be hindering performance.
    Seems if the air being drawn through the router could be dissipated away from the cutting area, the chip pickup would be free to work far more effectively.
    Also - for same airflow rates, isn't a smaller hose going to generate faster flow velocity? Going to a 4" hose gives you tons of flow, but if the air is moving slowly, isn't that counterintuitive since it'll stop you from being able to suck up heavier/larger debris?
    Quote Originally Posted by CarbonKevin View Post
    No. But, you can't use a 4" hose with a shop vac, and you cant use a 2-1/2" hose on a dust collector. With a router, it's unlikely that you'll get any heavy or large debris. There's a lot of info here on velocity and CFM.
    http://billpentz.com/woodworking/cyc...cs.cfm#Airflow
    Imo, the most important thing is to have a good seal with the brush. You'll never get 100% of the dust, but a good seal will get you nearly 100% of the airborne dust, and that's really all that matters. The little bit left on the table is quickly cleaned up with a shopvac. The main goal is keeping the rest of the shop clean, and that's easy to achieve.
    If you do want 100% dust collection, and have a 10HP or bigger spindle, you can try one of these.
    http://www.dustfreenesting.com/
    May 2005
    1662
    That 2HP Harbor Freight dust collector is a killer deal ! Unfortunately the nearest store is 200 miles and an international border away. Not impossible, but a hassle. How about one of the 1HP models from BusyBee ?
    http://busybeetools.ca/cgi-bin/produ...CT053&NTTYPE=H
    The best prices I could find in Canada
    570cfm for $175. Enough ?
    also 825cfm for $250. Honestly the most I'm willing to spend.
    Sorry, missed the Canada part.. Like I said, I use a 1HP dust collector, and cut pretty much dust free. It's not nearly as powerful as the HF, but get's the job done. It's quite a bit quieter then the HF, too.
    May 2007
    380
    When choosing a dust collector, keep in mind that the amount of flex hose needed for a CNC router will cause a fair drop in CFM at the collector. If you start with a low CFM model, you may be disappointed with the performance.
    John
    Jul 2009
    140
    Quote Originally Posted by cyclestart View Post
    Princess Auto had this guy for about half price a few weeks back...I'm beginning to regret not going for it then. Keep an eye out, though...it will be on sale again!
    http://www.princessauto.com/tools/co...dust-collector
    Jul 2008
    267
    I use a type 2 1/4" hose (8 feet of it) and put it into a dust deputy to a shop vac. Works very well. I have no need for a large 4" hose.
    My work is specialized cabinet building (speaker cabs), pine and baltic birch. Also lots of aluminum cutting and engraving. The machine only operates about 4-20hrs per month. Any more than that and I would be looking at a more sophisticated dust collection system, only to get the vacuum noise outside and a larger bin to collect dust in.
    Make sure to have a ground wire wrapped around the vacuum hose and grounded near your spindle.
    Here is a picture of my shoe.
    Mar 2009
    56
    Anyone try this design Vs a dust deputy. Seems simpler and easier to build then the deputy:
    http://www.cgallery.com/jpthien/cy.htm
    with a nice mod:
    http://www.cgallery.com/smf/index.php?topic=284.0
    Feb 2009
    1290
    Has anyone made a dxf of the Thien lid, say for a 5 gallon pail?
    May 2005
    1662
    Hah ! How did I miss that one ? Quality at PA is hit and miss (mostly miss) but at half of $199 a chance worth taking. Thanks.
Page 1 of 3 123
  1. Dust Shoe
    By indycraft in forum WoodWorking Topics
    Last Post: 12-11-2012, 06:17 AM
  2. The Split Shoe - Dust Shoe
    By Kent23 in forum News Announcements
    Last Post: 12-06-2011, 07:26 AM
  3. New Dust Shoe
    By Rocketman1 in forum Maintenance DIY Discussion
    Last Post: 11-11-2011, 05:41 PM
  4. My dust shoe
    By IQChallenged in forum CNC Wood Router Project Log
    Last Post: 03-05-2011, 04:05 AM
  5. Dust Shoe
    By Kent23 in forum Videos
    Last Post: 10-28-2010, 06:14 PM
