586,089 active members*
3,867 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Battery change OSP7000L
Results 1 to 6 of 6
    Jun 2010
    hi all
    I have an Okuma LU25 with OSP7000L controller.
    I have changed the batterypack , but i still get the alarm. As i understand , its needed a diskette from okuma to be able to reset this alarm.
    Any suggestions?
    Mar 2009
    1982
    do You want us to guess, what alarm message says?
    Jan 2010
    96
    Quote Originally Posted by bengt65 View Post
    hi all
    Any suggestions?
    You understand correctly. There is a Battery/Maintenance disc that resets the control data for the battery change. The service rep will have to do this as there is a procedure required. You will get this alarm until this is done.
    Jun 2010
    Smile
    thank you for your reply
    Im very far from the sevicerep, about 1,5 hour flight, so i wanted to do this myself.
    So if i could get the diskette and the procedure, i would do this myself.
    I dont think this is too difficult for experienced programmers or engineers to fix , with the right tools.
    It's quite expensive to fly a service rep just to reset this battery alarm.
    to the other post :
    Im sorry i didnt post the exact alarm , but it's obvious the batteryalarm, and the procedure for this, on this controller.
    Mar 2009
    1982
    It's easy to find solution starting with accurate alarm message on Okuma Alarm and Error list or Troubleshooter.
    I would try first bootable 3½" disk and enter maintenance or service on menu.
    There is another solution also - You can try re-install OSP software. It doesn't harms, You just need to prepare backup of parameters and user files.
    Jun 2014
    Re: Battery change OSP7000L
    Dose any one out there have a copy of the battery reset disc? Can you send me or better yet email a copy?
  1. Centroid M-400 CMOS BATTERY LOW VOLTAGE FAULT- WHERE IS THE BATTERY?
    By Russ Shugg in forum Centroid CNC Control Products
    Last Post: 01-11-2014, 03:01 AM
  2. Replies: 0
    Last Post: 08-23-2013, 02:38 AM
  3. Battery change and initializing position _ NL series
    By aidenkim in forum Mori Seiki lathes
    Last Post: 08-26-2011, 02:28 PM
  4. Hitachi HT 20 CNC Lathe "turret index time over alarm" after battery change
    By surfit in forum Uncategorised MetalWorking Machines
    Last Post: 02-02-2011, 04:35 PM
  5. Change Battery on Maho 600E, Phillips 432
    By Konrad in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 08-16-2010, 04:28 AM
