586,108 active members*
3,196 visitors online*
Results 1 to 6 of 6
    Aug 2007
    8
    Fanuc OMB Spin Not Safe Error
    Makino FNC106 - Fanuc OMB Control. Tool out of order & had a hard crash. Machine runs fine if spindle is not under a load. Will dry run program @ max RPM for hours, but when you put spindle load, returns error No. 2028 Spin Not Safe & machine stops. The spindle sounds fine & runs up to RPM fine. Spindle is not heating up. Machine is not running for a long duration to fault out, totally random.
    Feb 2009
    6028
    Is that the little Knee type Makino ?
    Aug 2007
    8
    No, fairly good size 24 x 46" CAT50 spindle. Ran ok all day. Intermittent problem at this point. Mike
    May 2009
    181
    any fanuc alarms?
    Aug 2007
    8
    No 2028 Spin Not Safe on console
    May 2009
    181
    you have to cal makino for that.. its their alarm
  1. Need to Open a safe
    By jimalb in forum Hobby Discussion
    Last Post: 06-04-2009, 03:30 PM
  2. Is Machinable wax safe ?
    By laszlozoltan in forum Safety Zone
    Last Post: 06-01-2008, 09:26 PM
  3. Is this safe?
    By foam27 in forum CNC Machine Related Electronics
    Last Post: 06-16-2006, 12:08 AM
  4. Is this safe?
    By Hack in forum DIY CNC Router Table Machines
    Last Post: 07-28-2005, 01:00 AM
  5. Is it safe?
    By kong in forum Gecko Drives
    Last Post: 11-24-2003, 04:56 PM
