586,102 active members*
2,442 visitors online*
    Jun 2006
    247
    line out start point
    The machine is a Nexus 510 vertical mill w/ Matrix controller
    problem is, whenever programming a line out with multiple depth passes, and using a specific start point. The start point I want only works on the first depth pass, then all other depth passes revert to the point picked by the control.
    This is a big problem when a face mill tries to plunge into the material on the second pass. So far I've been duplicating the unit with the programmed start point and incrementing the depth of the cut each time.
    Jun 2006
    247
    really???
    Feb 2007
    198
    Experiment - try changing the values of parameter E1 and E2 in the TPC page attached to your line out unit.
    -jim
  1. Use a point for the start point of a profile.
    By dcskid in forum BobCad-Cam
    Last Post: 03-18-2009, 04:31 PM
  2. Line tangent through point
    By mastercamguru in forum Mastercam
    Last Post: 12-07-2008, 01:26 AM
  3. re start point
    By woffler in forum BobCad-Cam
    Last Post: 11-06-2008, 02:56 AM
  4. Line Smoothing, point /line no identification
    By dz1 in forum Visual Basic
    Last Post: 12-15-2007, 12:03 PM
  5. line from point in angle
    By JSandSO in forum Autodesk
    Last Post: 01-29-2004, 03:28 AM
