586,103 active members*
3,404 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Editing a two sides of a rectangle
    greenene Guest
    I am pocketing 6 identical rectangles in wood. I need to increase the height of these rectangles without having to create new tool paths from scratch.
    Normally, when I edit the geometry of a piece, the program automatically updates the toolpaths for that particular geometry( The tool paths get the red crosses next to them)
    I am using the xform scale and y axis field to edit the rectangle. When I change the percentage that I've calculated for the new height dimensions, I get the new rectangle width.
    However, the toolpaths remain unchanged.
    I expect Mastercam to display the red x for the tool path, but nothing happens.
    I don't want to delete all the toolpaths just to make this one change.
    What I am doing wrong?
    tc
    May 2007
    312
    I have never known mastercam to automatically select altered geometery. Are you using HSM toolpaths or manual?
    Apr 2003
    3578
    I usually just use Xform and stretch and then Regen.. now you can go to your operation and pick the Geometry and then right click you chain and say re-chain and pick the adjusted geo and then regen and be on your way.
    Cadcam
    Dec 2008
    3109
    Have you used the "Tranform toolpath" function ?
    you create 1 or more operations and then define where this pattern is to be done
    ----modify the original operation ( geom, depths, offsets, blah-blah) and anything that uses that operation also goes "dirty" ( big red X ) , regen all, then post---- to easy
    It would probably be that the geometry you modified is not involved in the creation of those actual toolpaths
  1. NEWFANGLED CUT RECTANGLE
    By BOBINETTE in forum Mach Wizards, Macros, & Addons
    Last Post: 01-13-2010, 01:01 AM
  2. Adding drill points to a rectangle
    By Joe Rodney in forum Mastercam
    Last Post: 10-19-2008, 09:35 PM
  3. Small Aluminum rectangle pieces
    By TMaster in forum Employment Opportunity
    Last Post: 09-29-2008, 11:49 PM
  4. I beam vs sq. or rectangle tubing
    By DEW in forum Mechanical Calculations/Engineering Design
    Last Post: 08-03-2006, 04:32 AM
  5. G68 + Rectangle Cycle
    By Shizzlemah in forum Fadal
    Last Post: 01-26-2006, 11:17 PM
