586,461 active members*
4,140 visitors online*
Results 1 to 12 of 12
    Jun 2010
    Editing Ladder Logic
    Hi all
    I have a VTC200/50 and a relay on a board has gone bad on the tool unclamp solenoid valve, there are spare relays on the board but I can't figure out how to edit the ladder logic. I can only get to the ladder monitor.
    Thanks Chris
    24223
    Is this a Mitsubishi M50 or M500?
    Al.
    Albert E.
    Jun 2010
    Not sure where do I find That information
    The Only Info I can find is
    CNC Control Box
    Type VTC200B/250B #50 30HP M640M
    NC NO M640M004460
    Serial # 472A004
    24223
    On the controller itself, if it is Mazak, I can't help.
    Al.
    Albert E.
    Jun 2010
    MU515-12 Ver is on the sticker for the controller
    24223
    What make is the machine? Is it a Mazak?
    I see now its a Mits 640M.
    I am not sure if I have the info for this one and MEAU do not have it on line.
    If you get stuck, phone mits support in IL and get them to fax the instructions over.
    Al.
    Albert E.
    Jun 2010
    Yes Mazak
    Jun 2010
    I will Call them and see.
    Thanks for your help
    Chris
    Jul 2007
    284
    Yeah you have a Mazak Fusion control. I have heard it is not too difficult to edit the ladder. If you call Mazak they may edit the ladder for you but they will charge you for it and it probably will not be cheap.
    Jun 2010
    Thanks I have called and they want you to buy the whole board They will tell you how to edit any ladder logic. I think its crazy to go through all that trouble to resolder a relay when you could just change the address..
    Thanks Everyone
    Chris
    24223
    Can you identify the relay? Some used a printed circuit DIP relay other method was an output driver IC with outboard relay, previously I have located parts and replaced them for small cost.
    Al.
    Albert E.
    Jun 2010
    Thanks for all the help I have I did find the relay. I ended up unsoldering an unused on and soldering it back in place. I did find a person to give me the code and keystrokes to get into the control but still could not figure out how to edit the ladder.
    Many Thanks
    Chris
  1. Matsuura MC500 VS Ladder Logic
    By nnpepe in forum Uncategorised MetalWorking Machines
    Last Post: 02-29-2012, 04:48 AM
  2. CTR counters in Ladder Logic
    By Adam Rehorn in forum Fanuc
    Last Post: 08-07-2009, 08:20 PM
  3. How to decifer Ladder Logic???
    By theemudracer in forum Fanuc
    Last Post: 06-01-2008, 02:28 PM
  4. FANUC Ladder Logic Backwards?
    By obieron in forum Fanuc
    Last Post: 12-18-2007, 09:17 PM
  5. Ladder logic
    By Chris Roth in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 12-26-2005, 05:29 PM
