586,471 active members*
4,323 visitors online*
    Jul 2005
    179
    Tornado 200 tail stock
    Just finished getting the tailstock apart and freed up. After checking the hyd valves, I pulled the back of the tailstock apart and definately has had some moisture in there and lack of use. Will clean things up and get it freed up. Are there any vents or lube points for the tailstock housing, I don't see any?
    Thanks!
    May 2006
    82
    Hi H.
    I have never seen any lube points in there !!
    You will have to use some kind of a WD40 , & something else to remove all
    signs of moisture from there ,
    Jul 2005
    179
    Moisture
    Thanks C,
    That'w what I've been doing. Looks like either packing or a gland in there and I would like to pull it all apart and get it cleaned up. Has some rust up on the top and can't see what is on the other side of the gland. Enough to get it stuck I know. There is a small round cap on the side of the quill housing and I took the screws out but I can't easily remove it. I can see some silicone or something at the base of the cap. I was hoping it was a way to lube the other side of the gland, but with the amount of crap on the one side, it all needs to come apart.
    Hey, somebody was telling me about a spring loaded center that you mount in your chuck to do tube material. The tail stock pushes the material against this center and it has some teeth or something on it so you don't need a lathe dog so you can turn between centers. Do you know what that is called? edit: just looked in MSC, its a face driver, duh......
    Thanks for all your help, I appreciate it.
    H
    May 2006
    82
    H. Sorry !! i'm the maintenance Tech. down here , you are not talking about a bar puller ? are you ?
    The T. stock cylinder you should be able to actuate it just by air press,
    with an air hose
    Jul 2005
    179
    Tail stock
    Nope, tail stock. Had a bunch of moisture related crap in it and was stuck in the extended position. Cleaned it out and works like a champ.
  1. SL10 Tail stock alignment
    By Joseph Souza in forum Haas Mills
    Last Post: 03-02-2010, 02:46 AM
  2. TAIL STOCK
    By bruiserba in forum Okuma
    Last Post: 12-06-2009, 01:17 AM
  3. TAIL STOCK OSP5020L CADET
    Last Post: 11-23-2009, 01:50 PM
  4. Tail stock wont Advance
    By Jedi in forum MetalWork Discussion
    Last Post: 11-16-2006, 02:20 AM
  5. head stock and tail stock chucks
    By mocnc in forum DIY CNC Router Table Machines
    Last Post: 10-20-2004, 03:16 AM
