586,115 active members*
3,232 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > Bridgeport Interact 2 -- tachometer mode vs. voltage mode?
Results 1 to 3 of 3
    Oct 2006
    181
    I am converting a Bridgeport Series II Interact 2 CNC mill to EMC.
    I am currently using Advanced Motion 30A8T drives for all axes.
    The drives give me a selection of tachometer mode (with feedback from motor's tachometer) or voltage mode (which means output the asked voltage without any regard for motor feedback).
    The question is what mode to use. Voltage mode seems to be safer, in that if a tachometer breaks or stops sending signals, it would not go into a runaway mode.
    Am I losing anything such as accuracy, by not using tachometer feedback?
    Dec 2003
    24221
    You should have torque or current mode option, if so this is the one I use and is the method recommended by AMC for CNC application.
    Also it is easier to tune as there is no 'inner' loop the gain is normally turned to max and the feedback to min.
    Voltage is just an open loop speed control.
    Al.
    Albert E.
    May 2007
    781
    Tachometer feedback gives you smoother motion at very slow speeds if you are stuck with lower resolution encoders. Without it the control has no idea if or how fast the axis is moving until the next pulse from the encoder and at very slow speeds that can be a significant period of time.
    On newer machines part of the reason you see very high count encoders is so they can get smoother movement at slow speeds without haveing tachometers.
    On a machine like this the benifits of tachometers would be minimal.
  1. What is - Torque Mode? Position Mode? Speed/Velocity Mode?
    By sunmix in forum Servo Motors / Drives
    Last Post: 01-20-2024, 10:34 AM
  2. spline mode nurbs mode
    By cooltool in forum CamSoft Products
    Last Post: 03-10-2009, 08:03 AM
  3. Bridgeport Interact 1 MK2 - Input Voltage
    By palikalsi in forum Bridgeport / Hardinge Mills
    Last Post: 11-08-2008, 02:42 AM
  4. Bridgeport S1 BOSS6.1 No Jog or Edit mode
    By NeophyteJay in forum Bridgeport / Hardinge Mills
    Last Post: 10-22-2008, 01:20 PM
  5. peak voltage half step mode
    By dfv in forum CNC Machine Related Electronics
    Last Post: 08-09-2005, 03:56 PM
