586,103 active members*
3,304 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > SuperMax Turning Center w/ Fanuc O-T, Won't thread
    May 2008
    7
    We have a Super Max turning center here, model YCM-TC-15 with a Fanuc O-T control. We can't get the machine to thread, all parameters are on and we have tried the G76 code and I think a G32.
    Any suggestions? I am not the programmer but I will pass the info to him in the shop.
    Thanks!
    Ryan
    2932
    What happens when you try to thread? Can you post your program here? Maybe we can help.
    24221
    Is the spindle encoder OK?
    Will it do CSF as a test?
    Some encoders are driven with a small timing belt that might need replacing.
    Al.
    Albert E.
    May 2009
    181
    does it just sit there? if so it might be spindle speed arrival signal, or the position coder is bad..
    try turning on the dry run switch.. if it works it will prove my theory
  1. thread turning fanuc 10te
    By bruiserba in forum Fanuc
    Last Post: 03-27-2010, 07:01 AM
  2. ALARM 9034 in Fanuc oi mate-TB turning center
    By shavad_ind in forum Fanuc
    Last Post: 02-03-2010, 01:41 PM
  3. Turning Center G40 G41 and G42
    By jorgehrr in forum G-Code Programing
    Last Post: 04-14-2007, 04:48 AM
  4. Looking for help with Okuma turning center.
    By shawn45223 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-08-2007, 12:06 AM
  5. Turning center sale
    By bdrmachine in forum Uncategorised MetalWorking Machines
    Last Post: 01-10-2007, 02:23 AM
