586,713 active members*
3,010 visitors online*
Results 1 to 10 of 10
    Jun 2010
    Question direct control / direct phase
    hi guys
    im new to the forum (so be nice )
    anyways ive been building up a small cnc mil and i have a very basic driver(if it can even be called a driver) the driver uses 3 uln2803 chips
    atm i have 8 bipolar motors (2 for each axis except for the one with four) and i am wondering if i can configure emc to control the motors (basically put)
    my set up is simmilar to this just running with slightly better stepping motors
    this is a first build for me and if you guys are interested in pics i dont mind posting them
    thanks in advanced
    wez
    Nov 2005
    496
    read this from manual:
    http://www.linuxcnc.org/docs/devel/h...stepgen.9.html
    stepgen can control stepper coils directly though it is not commonly used.
    Jun 2010
    thanks for the reply (considering its early morning for you guys)
    im guessing there is no gui for stepgen? but then again i guess it cant be that hard to set it up.
    spent up to 6 hours yesterday trying to find this
    Jun 2010
    Question
    ok so i went through both the intergrator manual and the one posted but i dont understand how you set up the pin outs and how you get it to run with emc2
    thanks
    wez
    24223
    Quote Originally Posted by djwez View Post
    hi guys
    Are we anything but...?
    Al.
    Albert E.
    Jun 2010
    Al.
    haha so far im liking this forum
    now back to my problem (lol) been spending waaaay to many sleepless nights trying to figure this stuff out
    Jun 2010
    anyone able to help me out?
    im just confused about how i load stepgen into emc2
    i have read that you edit the core_stepper file but i have no idea where it is located. the other thing is i am planning on useing the 8 / 10 step config but im not to sure how you set it up (ive seen the ones for 2 phases but not for 4)
    oh ja and the pin out... how would i go about coding the hal file so that i have my pins all in the right places (eg pin 2 x axis phase 1, pin 3 x axis phase 2......)
    thanks.... starting to get on my nerves a little
    (oh ja and im not a resident linux user hence not really understanding the code)
    Nov 2005
    496
    I suggest you make a config with stepconf, then modify it to use different stepper control.
    after stepconf finishes the config folder will be under home/yourname/emc2/configs/yourconfigname
    open the yourconfigname.hal file and look for this:
    loadrt stepgen step_type=0,0,0
    change it to something like:
    loadrt stepgen step_type=9,9,9
    mode 9 produces signals for half stepping 4 phase steppers for unipolar steppers.
    there are other types of modes see the manual.
    then look for :
    net xstep => parport.0.pin-02-out
    setp parport.0.pin-02-out-reset 1
    net xdir => parport.0.pin-03-out
    change to :
    net xphase-a => parport.0.pin-02-out
    net xphase-b => parport.0.pin-03-out
    net xphase-c => parport.0.pin-04-out
    net xphase-d => parport.0.pin-05-out
    do the same for y and z do you have enough parallel port pins?
    look for :
    net xstep <= stepgen.0.step
    net xdir <= stepgen.0.dir
    change to :
    net xphase-a <= stepgen.0.phase-A
    net xphase-b <= stepgen.0.phase-B
    net xphase-c <= stepgen.0.phase-C
    net xphase-d <= stepgen.0.phase-D
    save that and run EMC.
    if I haven't forgot anything then that should work for you.
    Remember if you run stepconf again it will over right these changes you just made.
    Note that I have not ever done this - so no guarantees it works out-of-the-box.
    Hope that helps you.
    Jun 2010
    thanks chester88!
    last night i stayed up and chatted to a few of the guys over here and they explained a bit of this to me.
    to config the pins i have to go to file called standard_pinout.hal and core_stepper is the one with the phases.
    only problem is im getting errors every time i try to run emc2 after i have done the changes. maybe ill create a new machine profile.
    thanks for the help
    Feb 2013
    Re: direct control / direct phase
    hello guys i was wondering if you ever got this working and if so to post a hal file or other info about it. i know its long since this thread was active but I'm curious non the less...
    thanks
  1. CNC Direct THC
    By Dizzy_G in forum Waterjet General Topics
    Last Post: 07-27-2013, 10:16 AM
  2. Direct machine control with Alibre CAM
    By jviss in forum Visual Mill
    Last Post: 09-14-2012, 09:24 PM
  3. DNC direct numeric control
    By AMTB in forum DNC Problems and Solutions
    Last Post: 04-21-2012, 07:12 PM
  4. Stepper direct control
    By Holzwurm56 in forum Open Source Controller Boards
    Last Post: 01-14-2011, 05:32 PM
  5. port pin setu[p - direct phase controller
    By Andy Sayno in forum Mach Mill
    Last Post: 09-01-2007, 04:09 AM
